1) Its in AS on the STi, on 7.5" rims. There were a couple of competitors in BS that ran 275s on 7.5" rims on the same weight car (350z). Not heating up the tires as much was an advantage as with the front heavier car they don't overheat so they wear *better*
2) 7.5" wide wheel. I wouldn't have believed either that they fit, but carter made me into a believer
3) Didn't think about that. The 275s would probably be a bit heavier. With me running heavy wheels already..hmm......I will check into weights...
Here is an excerpt from an email from carter on 275s on a 7.5" wheel
"We are running Kumho victor racers and Hoosier 275's
on 7.5's. They fit pretty good, I would not say
perfect. both tires bulge a little but I do not think
it hurts performance much. We could tell a big big
difference between the 245's and the 275's though. The
275's are much better and I would recommend trying
them. You have to remember that my car is very heavy
(3150) and with no camber adjustments up front. This
puts allot of stress on the front tires so the 275's
can handle it much better.
-Tom
