Keith Quistorff wrote:
A lot of good points/counterpoints here, excellent discussion!....
....PAX is developed from results of specific events, those where the cars are prepped to the extent of the rules on the best rubber, and top level drivers understand the best set ups for their driving style, course conditions, etc. The typical "local" driver, however, will have a much better PAX result in a lower PAX car than a higher PAX car. For example, when I ran in GS a couple years ago w/my E36 325is, I consistently finished in Top Ten PAX at our events. Now that I'm running in SM w/my E36 M3, I only finish in Top Ten PAX on rare occasion. The two cars are very similar, same body, etc., and I'm very confident my driving has improved. But it's obvious it hasn't improved to anywhere near the "national" level, hence my lower PAX Index results.
From this standpoint, I agree with eliminating PAX classes....
Keith, I agree. It is an excellent discussion. But I am curious about something….
I have heard the theory about how it is easier to place higher in the results with lower PAX cars. And I even remember hearing an explanation that I could agree with! But I can't remember what that explanation/logic was. So I am not sure if I follow your example.
I have no idea how competitive an E36 325is was in GS or your current E36 M3 is in SM or what the prep level is/was for both. But could it be that the prep level of that car in GS was closer to the max for GS than your current E36 M3 is in SM? So if the GS car was at a higher prep level you should have placed higher? Also if it has been a few years ago, I don’t know if you can easily compare PAX results when I would expect that a good deal has changed between seasons. Last season I was 2nd in STS. This season with better driving (I think) and slightly better prep level in the same car I was 6th. So competition level can change pretty quickly even without throwing a change of car and class into the mix.
If I was to personally try to come up with a way to support the theory that lower PAX for the typical driver causes higher PAXed results, I would say that classes with a lower PAX contain cars that are just inherently slower (duh!). Things happen faster with faster cars. The limits are higher; elements come at you faster; the penalty for screwing up can be more serious; etc. I would say it probably is just much harder to drive a high PAX car at the limit of its ability. I expect that there may not be as huge of a time difference between an “average” and “top” driver in a low PAX car. I would however expect a larger time difference between an “average” and “top” driver in a high PAX car. So if you are not a national level driver, a high PAX car would be hurting you more than a low PAX car would.
I am not personally sold on the theory yet, but I can see that it might be true.
On top of that we don't even talk about how the TIR people get the shaft when it comes to overall PAX results. So lets say you were a top driver in an *SP car, but was using street tires in TIR class. You might be able to rule PAX and your open class if you ran "R" tires, but with your street tires you are NOT going to place as high in the overall PAX results as you should. Basically TIR participants just filter towardt he bottom in the overall PAX results.
Ok, now the following is not directed at Keith at all, but is just a new conversation item to piggy back on top of the theory that Keith mentions above. And that is the validity of PAX and the impact of the above theory (assuming it is true)….
Does it even matter if average drivers place higher locally if they drive lower PAXed cars? It only would if you care about PAX results. If you care about PAX results and you end up getting placed lower than someone that you feel is not as good as you because of the above theory, well then you just need to make some type of change. Either you stop caring about placing lower in the PAX results and focus on your open class performance. Or you play to win PAX style. You stop driving your high PAX car and buy and prep a PAX winning car!
