BriceJohnson wrote:
If I want to be pushed, shouldn't I run in a class where pushing myself harder would actually have some result as far as where I stand?
Hi Brice, well, if you want to push yourself to improve, I would suggest you pick someone in your class who's routinely beating you, and use them as a "mark". Then each event you can see how much better you did against them than last time. Whether it's in HS or TIR doesn't matter, but your mark should ideally be someone who's going to be at every event you're going to. If you were thinking of using Mary E as your mark, you should know that we're planning on cutting back the number of events we run this year. But Bernie could be a good comparison. I don't know how consistent the group of drivers in TIR class is (I haven't checked), but if there are good consistent drivers there then one of them could be a good mark. A disadvantage of using a TIR driver from a different "base class" is that you could only compare PAX times with him/her, and they're only available twice per event when results are posted. If you picked an HS driver as your mark, you can compare run times directly.
I'm not here to build my ego, I'm here to try and get better, and its fun to actually have other people around you to push you in your class, rather than trying to "not be beat quite as bad".
It seems to me that if you pick someone faster than you as your "mark", then your goal should
precisely be to "not be beat quite as bad". If you are truly focused on improving your driving, your ego shouldn't come into the picture.
One thing I would strongly encourage you to do (and it sounds like this is your plan already) is to stay on street tires for
at least your first full season, if not longer, even if you choose to compete in H Stock against cars on R-compound tires. Street tires slide more easily, recover more easily, and communicate better than race tires, and will teach you how your car handles (and how to handle your car) much faster than if you jumped right in on race tires.
Hope that helps.
Carl Fisher
Be Cool to the Pizza Dude:
