Aaron Buckley wrote:
I know a lot of people that have 710's cord like that. I'm not sure why it happens in that manner, but that is not unusual. What is unusual is it was only with 80 runs or so. Most are seeing 100+ runs out of 710's. Laurinburg is awfully hard on tires and I know you've run there a good chunk, so I guess it may not be that surprising...
You'll find pictures like that on SCCAForums with people asking the same questions when they see that 'peel back'. It kind of reminds me of how the BFG G-Force R comps used to cord. - AB
Thanks Aaron, that's what I was looking for. I'm a little bummed, because I was used to getting 120-140 runs out of Victoracers on the E30. However my driving style has changed a bit with the M3 -- sometimes the only way to get it "handling" properly is with a little rear tire spin. So I'm much more aggressive in the M3 than I was with the E30 325is, and I strongly suspect this is the root cause of the high wear and the big corded patch.
I'm starting to mentally calculate how long it would take for a good suspension on this car to pay for itself in tires. I'm sure that I would be able to drive more smoothly and I'd probably be back in the 100+ runs on a set of tires.
One thing I think I learned is that I flipped the rear tires too late at 60 runs. The inside half of the tire wears much faster than the outside edge because of all the tire spin. That "thin" part is what corded, now on the outside, on that tire. I need to do it at about 40, not 60. The fronts however are about perfectly worn... But I'll need to toss them anyways -- the wear indicators are gone, probably very little life left in them.
