The analysis of this can be kind of odd, not all classes were represented in open (or tire) at every event, so how do you judge the real impact without skewing the numbers high or low...
How right you are! My head was hurting when I stopped looking at the numbers last nite! FYI..I did part of my analysis by looking at the number of "class occurances" that had a TIR class. It varied per event by 1 or 2. Doing it that way makes getting your arms around it a little easier.
As I said a couple of posts ago, the issue of open class dilution is not just one of TIR. We really need to look at PRO and NOVICE at the same time and decide, as a club, if we want to continue supporting multi-tier racing based on driver skill.
If the answer is YES, then we need to clarify TIR as a stepping stone and put the appropriate rules around it (as well as tighten up the purpose of Novice and PRO).
If the answer is NO, then we need to adjust TIR so it's purpose is clearly aimed at the original TIR purpose. PRO and NOVICE would be impacted accordingly.
I think my opionions are clear on the subject, but I would like to hear some additional thoughts from others specifically about the value of having 4 skill-based classes ("JV" as an earlier post called it). Leave the tire brand argument out for now - I'm interested what people think at the fundamental level.
