jimpastorius wrote:
scottjohnson wrote:
Just to clarify, as Jim has properly quoted, I said "ban/change" as I see it, a tire exclusion list is a "change."
I *did* read the posts.
If you read the posts on this specific topic, then you are guilty of misquoting. No one mentioned the term "ban" in conjuction with TIR. We have gone there before and it is pretty much a forgone conclusion TIR does serve a very useful purpose.
I re-read and Jim is correct. There has been no proposal to ban tire class, just Pro and Novice, and certain tires from TIRE class (my apologies to all that I may have steered wrong).
Cliff notes: It isn't broke, I don't think it needs fixing.
That said, the more I look at it, and the more posts I see from the people who actually run/have run in TIRE class (that is the topic of this thread, not Pro or Novice - I will save those discussions for a later date), the more I think that we are trying to create a problem where there is none.
I think peer pressure would be a better solution to any issues that people may have. If someone runs all 8 events and dominates all 8, then they should be encouraged to move to open class, we shouldn't force it on them, or change the class so they are ineligible.
There will always be people that cherry pick a class, it's unavoidable, if they chose to do it in TIRE class then so be it, it's likely they won't have many friends or much fun at the events.
snip: lots of irrelevant stuff deleted.
