Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Feb 14, 2006 2:36 pm
a good semi-novice can probably tell the difference between 2lb increments (or less) and play with them to set the balance.
Wow - I wish I could feel a 2psi difference! :shock: It takes about a 5-10psi difference for me to be able to feel the car doing something differently, depending on the tire. :lol:
Could it be I'm just an AWD hack? :D
PostPosted: Tue Feb 14, 2006 2:46 pm
You should be able to tell with the STi with the mojo torque you have. I *thought* I could tell when I played with it on the 070s by raising the rears by 2 psi.
A 1-2 psi change in the rear tires of the Talon made a big difference when I was driving it. I used to be an AWD hack too ya know. :wink:
PostPosted: Tue Feb 14, 2006 2:50 pm
It appears you all had different amounts of hack dialed in. :lol:
PostPosted: Tue Feb 14, 2006 3:42 pm
With the RE070's on the RS or the WRX I had to change the pressure by about 10psi to tell a difference. Haven't played with them at an autox on the STi, but just driving around I can't feel a difference between 25psi and 40psi. I actually got a puncture in one when I first got the STi - kinda thought it looked a little low (just barely looked different than the others) - when I checked it, the needle didn't move at all. Zero pressure. :lol: RE070's pretty much have the stiffest sidewall of any street tire, for those without experience with them. Compared to my Azenis RT615's it's like driving around on solid rubber tires with no air inside.
PostPosted: Tue Feb 14, 2006 3:51 pm
Neither can I. I thought we were talking about during AX runs? :?
PostPosted: Tue Feb 14, 2006 4:04 pm
Brian Herring wrote:
IIRC, the majority of NOV would have little to NO experience with autoXes, and also the familiarity with the club. IFF we had bunches of NOVs running around, it makes it hard for a TnT day to work in it's fluid nature without having to worry about someone 'lost' accidentally finding their way on the slalom course/skid pad/drift area.
Absolutely, this is the main important point. I think we actually agree. I will merely observe, however, that the majority of NOVs are not entered for the TnT, but for the Novice School; I'd kind of expect that a NOV who took the trouble to enter in TnT would know that it was what its name implies, with no novice support.
TnT == People who need some time to fine tune their cars to prepare for the season
NOV School == People who need some time to fine tune themselves for the season
No reason that I see that those two are mutually exclusive.
Of course, that is just my interpretation, but it should be stated in the signup area for each event so the requirements are cut and dry.
Do they need to be cut and dry? The main requirement I see is familiarity with the club and the operation of an event. Having enough knowledge and ability to benefit from a TnT is certainly not required (should there be a technical written test before accepting an entry?), as long as no-one gets in the way of those who do. It's theoretically possible for someone to have been autocrossing for ten years with San Francisco SCCA to turn up to the TnT and have no idea how Tarheel runs things, while someone who's run just one Tarheel event may have just "got it" right away.
I must admit I'm kind of playing devil's advocate here. As for my actual position, I'm agreeing on the main point, but see some room for flexiblity. If the guy running NOV knows his way around an event and can be self-reliant, then I see no reason he shouldn't run. Some people get that in one event, for others it takes a season.
Martyn Wheeler
PostPosted: Tue Feb 14, 2006 4:06 pm
I thought this thread was about if Novices were going to be allowed to run or not. Maybe this guy that has signed up would like a chance to make different plans if he's not going to be allowed to run.
Hasn't the no novices at a Test & Tune been a standing rule for as long as time?
PostPosted: Tue Feb 14, 2006 4:09 pm
it was invoked on me last season. hence the sour grapes comment. i didn't really want to go anyway. :twisted:
PostPosted: Tue Feb 14, 2006 4:11 pm
I know it was! It's only fair that we extend the courtesy to our current non-novices. :)
PostPosted: Tue Feb 14, 2006 4:16 pm
Okay on a serious note, there are several issues that come into play with Novices at a T&T.
1) Historically, there has been limited space at T&T's, so we tried to offer that space to experienced folks first.
2) As a general rule, novices should be paired with a non-novice while working the course. If there's fewer people, we may only have one person per station.
3) The novice may not receive the normal amount of attention that they would at a novice school / autocross.
I certainly can tell a big difference with the TA with 1-2 psi. Same with the 3rd gen TA I autocrossed back in the 80's. Kit says the Mazda 3 is sensitive to small changes too, especially at the rear.
But that's both on street tyres. Supposedly the Hoosiers I'll be on this year aren't very sensitive to it -- I'm figuring to "set and forget" for at least the first few events.
Martyn Wheeler
PostPosted: Tue Feb 14, 2006 5:33 pm
Vincent - I know what the discussion was, I was just making a separate observation about the "just driving around" thing. But I think my day-to-day "just driving around" would probably be a little more intense than a typical novice's autox run.
:lol:
PostPosted: Tue Feb 14, 2006 9:44 pm
[quote="MartynWheeler"][/quote]
Is that THE Martyn Wheeler? It has to be.
Martyn, what happened to ripping it up on two wheels???
PostPosted: Tue Feb 14, 2006 11:59 pm
Um. I hate to be called "THE" anything, but yeah, that's me. Still on two wheels, but I haven't ridden on the track in a while now. These days I'm strafing twisties on a Softail Standard and having a blast with it.
I figured you had to be THE Donnie. Knew you were into Spec Miata, finding you were in Tarheel was kind of a surprise. Guess it shouldn't have been. :P
Martyn Wheeler
