Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 07, 2006 10:10 pm
Double wishbone vs Mr. McPherson
Shorter wheelbase
Lower weight
Honduh's r0x0r teh bewbies a priori
PostPosted: Wed Feb 08, 2006 5:13 pm
You gotta race the truck
Matt Nicholson wrote:
Torque wins autox's not HP....
The Civic has niether. Esplain that one...
I haven't made a THSCC event in a while :( But I have a REAL limited slip now and I run STX in Highlands night series. I own it (when my co-driver Walt Puckett doesn't show...)
It was a comment about how the celica makes power, at the very top of the rpm range, same with its torque.
While a Civic may have less peak hp and torque, it makes more of it down low, and sooner vs the celica.
91 Jetta GLI STS/DSP 111
85 Porsche 944 ASP 11
PostPosted: Thu Feb 09, 2006 10:11 am
You've obviously never saw my dyno charts after the ECU tuning. I made 20#ft more than stock from 3000 rpms up to 6500 rpms. I had a lot more torque than any Civic, all over the curve. When you compared torque/lb, I was on par with the top Civics. My problem? Wheelspin. In a straight line, there wasn't a single car (RSX-S included) that was STS legal that could hang with mine. Problem is, coming out of a corner, I could barely get in the throttle, even with 1500 Newtons of compression and 900# rear springs keeping as much of the front tires on the ground as possible. - AB
PostPosted: Thu Feb 09, 2006 11:48 am
Plus, Aaron's a hack - that's a big handicap right there... :roll:
:wink:
PostPosted: Thu Feb 09, 2006 11:54 am
:wink:
I agree... although, I think this hack has a good chance of doing well this year in an RX-8 ;) - AB
PostPosted: Thu Feb 09, 2006 12:18 pm
Yah, maybe... and I think this ex-STS hack has a good chance of driving while looking through the side windows a lot this year. :D
PostPosted: Thu Feb 09, 2006 3:09 pm
Aaron Buckley wrote:
...even with 1500 Newtons of compression and 900# rear springs keeping as much of the front tires on the ground as possible. - AB
Damn, boy- that's a lot of Newtons! If I ate that many, my front tires would be planted but good! You probably have a more balanced weight distribution, though. Have another 1500 and see if that helps... :wink:
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Thu Feb 09, 2006 5:30 pm
I saw your dyno at the last THSCC day, and unless it got a lot better than days' runs I'd still bet on a STS tuned civic being faster.
PostPosted: Tue Mar 14, 2006 10:37 pm
Holy Cow batman!!! We have 11 STS drivers for the first event if you count the NOV drivers, 7 if you go with classed drivers. Should be an interesting year if this is any indication!! BTW Mitch, glad to see you made it!
Let the drifting begin!!
PostPosted: Tue Mar 14, 2006 10:46 pm
WOW!!! That's almost as big as street tire class!
Duck and run... :)
PostPosted: Wed Mar 15, 2006 11:33 am
Crap, I had forgot to register. :oops: Add another to the STS list. :)
