Chuck Branscomb wrote:
At the BMWCCA Oktoberfest in September, the autocross was run on the Patriot Course, and they (Marv Jensen and company) did an excellent job with cone placement to keep speeds in check while still allowing for a fun and challenging autocross. It was still pretty fast however; in the M5 I was almost touching the rev limiter at the top of 3rd gear down the straight toward the right hander prior to the uphill (south course corkscrew backwards) which is ~100mph. The course started right at the exit of the pit and ended up the hill from the pit -- probably about 3/4 of the way around.
The Patriot course is a very challenging course to drive without the cones. Almost every corner has a "feature" to it (i.e. uphill on camber to the apex switching to downhill off camber). I've walked the course a number of times, made extensive notes, driven it in the THSCC HPDE last year and then the CCA event this year, and it is an amazing little course in my opinion.
I think it all comes down to cone placement as to whether it will be a safe and enjoyable autocross. If it is like the CCA event, it will be wonderful imo. If it is more like an open Patriot course, it will likely be a mistake to let inexperienced drivers loose on it. I have just a few pictures of how the first part of the course was setup with the cones at the CCA event I can post if anyone is interested.
Chuck
I agree with Chuck. I was up there as well running the autox during the ofest. They ran the Patriot course clock wise which I under stand is backwards from the normal way it's run. No blind curves in this direction. I personally had a blast and actually won my class (big day for Rodney!!).
It was a nice break running the autox on a course...an interesting combination of autox and track. If you get a change to run it, do it!
