Kevin Allen wrote:
Well, I have respect for Mike's abilities, but after consistently beating Aaron like a red-headed step-child for the past few years...
He is entertaining, though.
The way I look at car setup is this:
1. Drive it a couple of events & get used to it.
2. Start changing stuff to see what happens (not more than a couple of things at a time, though).
3. Adjust to the new setup in a couple of runs & then use the next couple to see how I like it.
4. Change it again before the next event.
5. Repeat steps 3 & 4 until satisfied, or until I trade it for something else.
Yeah, maybe I could've been faster with the 2.5RS if I went ahead & set it up 100% for the class per Corey Ridgick's specs & then just drove it and drove it and drove it. But how much fun would that be?
Hmm... depends on what your goals are. I think someone who has won the Top Gun trophy too many times and has comments like "Man, I just pitched it in there, and drifted the whole turn" isnt someone dead-set on being uber competitve. I mean, *I* beat you, so you can't be trying that hard
Needless to say, I would like to add that changing your setup is something that WILL mess up your game unless you car was utterly horrid to start with. This is something I wanted to experiement with last season, and I did it all over the place. Every fairly major change I made resulted in a "1 step backwards, 2 forwards' sort of result. Change is not something for one who wants instant gratification. It took me about 1-2 events to 'relearn' what I had changed. I think the most evident point for me is Laurinburg to Sanford (last two events). Changing from a 'stockish' spring rate to coilovers was a major setup in readjusting the car setup (camber, bars, setting the dampening right [new thing for me], readjusting my driving timing, etc...).
I think, in all, going through those 'growing pains' is something you have to do so you can say for yourself that 'you did it -- I am never doing that again'
. Just realize with any changes will come headaches... sometimes
Good luck on your decision. I would love to see you in STU as you are a great driver and personality to add to the STU pool.
- dow
