Chuck Frank wrote:
Sorry, but first, PAX is not even used in PS, There are factors, but they are set by the national staff and may be similar to but are not identical to the PAX factors.
Yeah, but they aren't pulled out of thin air. They may seem to be, but the adjustments are *supposed* to just be to compensate for launch difference capabilities between classes.
Second the factors are NOT used to determine who gets into the challenge, the first place drivers from each class are in, then the next X # of drivers who are closest to their class winners until they fill 32 spaces.
You're right, and I forgot about that. I should have known, too, since someone did run PAX numbers after Toledo and posted them and I was 27th, yet didn't make the challenge. I assumed it was the difference between the "real" PAX and the altered PS "PAX".
The factors ARE used to determine the ranking of the class winners for qualifying positions and/or to rank a tie in differential. Guess my not running in challenges gives me time to read the rule book!
True dat.
You have never been high enough or placed in a challenge to know but in addition to tires and other contingencies the first 4 challenge qualifiers and challenge places 1-3 also win money from SCCA.
Never even been in a challenge, but I would have in Wendover had we made the class (was only .3s out and the cutoff was over .5s). Sorry about the jab...I was having a bad day. It doesn't change my *original* point that you don't hear X class drivers complaining about someone beating them who had a weaker PAX, though. So I'm not sure what your point has to do with the topic at hand...
I'm also not sure what even bringing Kyung up has to do with anything, other than to help PROVE my claim that the CS PAX isn't weak. If it were she would have done even better in L1 and would have run the Finale in L1 and left CS Open for her husband to have a shot at so they could have both potentially won titles. She only lost L1 events to folks with GS PAXes.
But again, in the context of this thread, it doesn't matter. X class is the only way Tarheel has to keep from screwing up points. If you don't care about that and want to run an open class, fine. You can still measure yourself on the pax list.
As for ladies who run ProSolo who could win in their respective open classes, please name them. I checked some results and I don't see any non-skewed by outside factor results that back that up. Garfield consistently beat Beth in the same car (not to mention Chiles), Danielle hasn't really challenged CSP hard that I've seen (Rod beat her in the same car), Jen Merideth doesn't beat Marcus, etc. I'm just not seeing *clear* challengers for open class wins outside of Kyung. You're still probably right in that Aaron shouldn't make that comment in grid, however.
