jimpastorius wrote:
Case in point....pivot/corner. You brake early, get your turn started and begin to apply the gas (brake/turn/gas)..it does not matter what kind of a car. Now, where you might execute those will differ slightly.
While I conceed that the basics of driving ANY car will always be relatively the same, the implementation and timing of those basics WILL change based on setup, weight, hp, lateral grip, time of day, spin of the earth, etc...
So, my *personal* feeling out of it is if I am at the *intermediate* level, or such a 'level' where I am USED to the car and I am trying to 'fine hone' my responses with the car, it is not as benificial to me to put myself in another car where I am introducing even MORE variables that will show things I am doing wrong (because I am not used to that new environment).
My example with the pivot cone.
In an AWD FI car: I brake hard EARLIER with a heavy 34xx lb car, downshift to 1st, and tight corner + WOT + clutch slip on the way out... there is a fine line here to not bog the engine.
In a RWD NA car: I brake a little LATER with a 29xx car, Downshift to 1st, and tight corner + ease gas + clutch.... There is a find lne here not to smoke the rear tires.
While it would be 'fun' to get a different perspective, I would rather get more 'intune' with my car and the way I need to drive it to be faster.
Just my 2 cents.
- dow
