Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
 Post subject: Topeka update
PostPosted: Sun Sep 11, 2005 8:15 pm
Just call me Bo
Dang it! I'm selling this POS!!! Ryan and Karl were right!!!!! 17 year old Hondas suck!!!!!!!! :cry:
Ok, I'm kidding. :twisted: I am having some tranny troubles but considering the abuse I've put on the poor thing this year, I certainly can't complain. I have been adjusting my clutch all season and was running out of travel which I assumed to be a worn clutch. After having somebody change the clutch last Monday, it turned out the release fork inside the transmission was worn out and bending. As a result, my clutch pedal is a bit stiff from the decreased leverage and it is engaging right on the floor. With 250K miles on the drivetrain, I'd say its done pretty well.
I hoped it would make it through nationals but it only got worse after practice starts on Friday. On my morning runs on Saturday, I was having a hard time shifting into 2nd gear but a little bit of force did the job. By the afternoon, I couldn't even force it into 2nd gear shifting at redline and wound up having to coast until the rpms dropped into the 5.5K range before it would slip in. No grinding or anything, the thing just wouldn't shift.
After talking with a few people Saturday night, I decided to try and bend the bracket outside the tranny which seemed to get me about 2mm of extra travel. Being paranoid about it still not working, I wound up short-shifting (5K rpms) into 2nd on my Sunday runs which worked great. Needless to say, averaging 2.5s 60' times with a couple of high 2.4's thrown in for good measure wasn't getting it done with my competition running low 2.2's and high 2.1's. With the run to the first corner being ~140' with no braking, I don't even want to know how much time I was giving up by the 2nd corner.
The only other problem I had with the car was I couldn't loosen it up enough. The grip out here is everything everybody said it would be and I still didn't leave myself enough adjustment to get the car to rotate-- rookie mistake. I may try to play with the rear toe before Tuesday but it is hard to keep it square without going to extremes. Or an alignment shop…
I felt like I drove well on Sunday once I got used to the grip so I was very happy about that. I had fun which was the most important part and learned (well, reinforced really) a few valuable lessons.
1. Don't show up with a half-ass car and expect to win. Trophy? Sure. Win? Not a chance.
2. Don't take 15 runs on slippery asphalt with old tires the weekend before you run on uber-grippy concrete with new tires. *This will be somewhat irrelevant by next year...
3. If there is something busted on your car, fix it *before* you show up at a big event. Don't just hope for the best 'cause your too tired (or lazy) to do something about it. See point 1.
4. Don’t get frustrated with things you can’t control. I did pretty well with this one and wasn’t even upset when I couldn’t shift. I think most of it was the fact that I felt like I got nearly all I could out of the car in its current state. My last 2 runs on Sunday were a little sloppy but I was trying as hard as I could and just pushed the envelope a bit too far. I usually get upset with myself when I don’t feel like I’ve driven well but that wasn’t the case here. Or maybe it’s just the new medication I’m on! :shock:
Anyway, I’m looking forward to nationals and would be very happy with a top 5 finish. Even if I can’t pull that off, I’ll still be happy if I can flog the car within an inch of its life and feel good about my driving.
Eric and Donnie had some shock issues over the weekend which included the rears missing half of their normal travel! They recently had them rebuilt and the place did a very poor job reassembling them. I hated to see those guys dealing with a busted car after all the effort they put in getting things ready. They can fill in the rest of the details if they are so inclined.
I didn’t see much of Donna and Chuck other than in passing and I’m not sure where they wound up. It was at least nice to see some other familiar faces in the sea of new people and confusion of the big event.
PostPosted: Sun Sep 11, 2005 8:44 pm
Sorry to hear about it. Its not that hard to change so I hope you open it up and get a new fork in there.
Donna trophied with a 4th in Ladies
Eric got 5th with what looks like a case of cones.
Donne was 11th
Thats all the locals I see.
PostPosted: Sun Sep 11, 2005 10:19 pm
Jim,
For what it may be worth:
The South Course (where the Pro is held) has usually been relatively low grip compared to the North Course for me and my slicks (C Mod FF on Hoosier 25A's).
Conversely, the South Course is SMOOTH compared to the North course. If at all possible adjust the car and the driver with BUMPS and JUMPS in mind. I set mine with stiff springs and compliant shock "high shaft speed" valving.
Finally, give yourself LOTS of time for course walking . . . especially the North Course. Lots of decisions to be made regarding the optimum line given the bumps, up hill and down hill stuff, off camber, on camber, etc. Remember you only get three runs per course. You may find that trophying is tougher than you expect . . . but if I could do it you can too.
GOOD LUCK
PostPosted: Sun Sep 11, 2005 10:40 pm
Jim,
A couple of other comments:
The "sight lines" during course walks can get very difficult due to the very large number of people walking the course . . . especially during the mid day course walks (if you run afternoon heats). Walk early in the AM and late PM to actually get to see the courses. FYI by this time Sunday night I would have walked both courses at least once if they were set up . . . :)
Note that the courses will be swept after each day and holes will be fixed. Typically no repairs are done during the day so if you run late it is typically a good idea to do mid day walks to see where the gravel, etc. has collected.
Tech for Nats will be busy. Do it as early as possible relative to the days you run.
One trick is to get several copies of the course maps made from the "book". We had it done at the hotel.
PostPosted: Sun Sep 11, 2005 11:14 pm
Just returned from the PS banquet. Donna finished 4th in L1 at the Finale and also 4th in season points so she got to walk across the stage.
I demolished the front swaybar mount on the Miata at the Labor day T&T in Peru, and it was too far gone to repair on the road, but fortunately we had gotten the Celica back from Happy Japs with the new tranny and clutch installed in time to take it to Peru as a support vehicle. Just in case we had thrown a set of race tires in it. Good thing because I ended up driving it in the "1 eventers" PAX class in the Finale. I finished 7th out of ten, but was pleased with my driving, having not driven the Celi this season except for the one dry day at the Oscoda Pro (the 1 event that allowed me to run in the Finale) because I was only 1 sec out of trophies (4th) the position held by by Jean Kinser-Dana the owner of the Evo schools.
Now we have to change gears as both Donna and I will be driving Mark Chiles' HS Mini Cooper Tues-Wed in the Championships. Wish us luck!
PostPosted: Sun Sep 11, 2005 11:18 pm
Just call me Bo
It's honestly not a big deal to me at this point. I don't have the energy or motivation to deal with it onsite so I will just take my chances with it the way it is. If it totally craps out, so be it. I'm really just here to have fun so I'm not going to worry about little details like my tranny blowing up. :lol:
Looking at the course maps for the championships, the start won't be nearly as important as the Pro courses. I'm hoping to minimize the pain and suffering by shifting early in the 1st turn(s) and just riding the limiter if the North course calls for 3rd. Hey, why just blow up a tranny when you can blow up a tranny *and* a motor! :thumbsup:
PostPosted: Mon Sep 12, 2005 3:32 pm
You can read more about our trouble here:
http://forum.miata.net/vb/showthread.php?t=150200
I've learned a couple things from this...first, go with your gut when it tells you in the offseason to get shocks rebuilt *then*. I should have done it almost a year ago and then we wouldn't have had this problem. Second, I learned to start trusting myself more when the car is acting odd rather than assume it's my driving.
The first thing was actually the most important, since now we've basically been driving a different car for three months or more because of the shocks changing on us regularly (the blown one was progressively getting worse, then we had to drive on Bilsteins a couple of events, then we drove on it some at the T&T before the swaybar bracket broke as well as the first day at the Finale with the bad rear shocks, and now we're back to what should be sane again). So needless to say, I'm just not driving as well as I was back at that last Laurinburg event. *sigh* I peaked too early, I guess. ;)
PostPosted: Mon Sep 12, 2005 9:06 pm
My brother, Adam Breakey, (a future Tarheeler) decided to make the most of all those free Evo schools he won. The placed 5th in SS driving the GT3, which earned him the final trophy spot!! He even beat a former jacket winner! Not bad for his first time in Topeka. Now he needs to put it together for the Nationals.
PostPosted: Tue Sep 13, 2005 9:33 pm
Well, Donna is 2.5s ahead after day one in HSL. She's pretty much crushing them. I heard Chuck is pretty far back in HS, but haven't seen those results (they are posted somewhere).
Jim is in second after day one and is about .7s out of first. He's driving *great* considering the leader probably has around 25% more horsepower to the wheels and a tranny in much better shape. Jim was trading blows with Seelig the first two runs, but Seelig really opened it up on the last one. I think Jim definitely has a chance to hold on to second, but the North course is a little more power hungry and I'm not sure he can close the gap. I think Jim is a much better driver than Seelig, though, so we'll see on that one.
Several of you know Tim and Rod, so I'll give their update...Tim jumped in the car after only running one little warm up event a couple weeks ago in it and is .2s off Doganis in second. He's driving *really* well. They're gonna tweak the car a little more and should have the handling even better for tomorrow and from what I know about Tim, I think he's got a great shot. I'd actually rather see him down .2s than up .2s after day one (I know, it's crazy, but...).
Eric and I had the worst thing imaginable happen. We registered with high numbers (yeah, our fault) and the bottom fell out after about 15 cars got runs but before we got any in. So he is 20th and I'm 27th and we're like 6 seconds out of the lead and several out of the trophies. It was drying pretty fast toward the end of our runs, but not fast enough. Oh well, you pick your numbers high, you take your chances. *sigh*
PostPosted: Tue Sep 13, 2005 9:36 pm
I thought that Tim wasn't doing any autocrossing this season. I assume that he's in Rod's ride.
PostPosted: Tue Sep 13, 2005 9:42 pm
I talked to my brother, Adam, today and he didn't sound too happy. If you look at the results, you will understand why. He is currently sitting 38th out of 56. 5.6 seconds behind leader Ian Stewart. Not where he wanted to be.
He said that his first run was in the rain on the rain tires, 3 cones, that sucked. Run number two was not raining but still wet and on R comps, that was obviously MUCH better (no cones) but still not as fast as he is capable of.
His third run is where things got weird. Apparently the course started with a slolam. When he shifted into 2nd...the car DIED!!! He has no idea what happened. So needless to say, he DNF'd that run.
Hopefully he can have 3 good runs tomorrow and get a feel for what he could have done and help boost his confidence more (like he really needs that!)
PostPosted: Tue Sep 13, 2005 10:15 pm
Just call me Bo
Donnie pretty much said it all in his post. About the only thing I can add is we had drying conditions during our heat after the bottom fell out during the previous heat (when Donnie and Eric were running). I managed to get a .5 second lead after the first run which was the first time ever driving the CRX in damp conditions. By the 2nd runs, the course was mostly dry and I got pushed back to 2nd by .08 seconds. The 3rd runs were on a nearly completely dry course and the grip improved an amazing amount. My third run was going great until I got greedy in a patience sweeper section and pushed out about 10 feet wide from where I wanted to be. Needless to say, it messed up that section and put me totally out of position for the next sweeper which led onto the largest straight of the course. I think I would have been right on top of the leader if not for that mistake but he handled the conditions better than I did and kicked my butt on that run. Even with the mistake I was happy with the way I drove especially considering that was the first time the CRX had seen anything other than bone dry conditions.
I really hated to see what happened to Donnie and Eric. They got totally screwed out of any chance of a good finish by a torrential downpour literally a minute before they were to take their first runs. It really sucks when your fate is sealed by something completely random and out of your control. Mother Nature can be a real pain in the keister some times...
Congratulations to Donna on laying the smack-down on the competition. She is in great shape for tomorrow and should come home with her 2nd national championship.
PostPosted: Wed Sep 14, 2005 6:54 am
Unfortunately this nationals is turning into a clusterf*** in so many ways...
Started with lightening storm as the first car pulled to the line resulting in a 2 1/2 hr delay of start. Then the CS gully washer. Then we get news that a major section of the N course pavement was breaking up so badly they had to alter the course (we were running S course) so any walk thrus were no longer valid, and they didn't finish the 5 th run group until after sundown (out of 6) so there was no time for evening walk thrus and the Tues 6th run group would make their runs Wed starting at 7:30... The gates don't open nor the sun come up until 6:30, so we "might get" 1 walk thru... :shock: :shock:
Not to mention I coned all 3 runs... :(
Donna is driving the best I've ever seen her do, I hope this doesn't affect her chances today...
PostPosted: Wed Sep 14, 2005 12:01 pm
Trying to follow the results, but very few are posted. So I emailed a couple of SCCA folks...
> Hey folks,
> Where are all the Nat'ls results?? It's hard to follow what's going on out
> there!
> Thanks--Mary E. Daniel
Mary -
We are having a file translation issue at the current moment, and we anticipate the results going up shortly.
I apologize for any inconvenience this has caused.
John Steflik
Webmaster/Graphic Design Specialist
Sports Car Club of America (SCCA) Inc.
http://www.scca.com
jsteflik@scca.com
800-770-2055
PostPosted: Wed Sep 14, 2005 1:33 pm
The results from day one ended up getting posted on www.sccaforums.com
This will let you see what happened out there yesterday. Hope this helps anyone who was looking for the results but couldn't find them.
2010 Honda Fit Sport
Couple of bicycles
