Chris Landi wrote:
I'm planning on going to NCAC to get exposed to what I perceive to be a higher level of competition due to this being a regional thing and to see if my AS competitors have been holding back during our local competitions
Is there anything I should know about in terms of how things are done at these types of events? Anything outside of:
-Arriving early
-Register/work assignment
-course walks
-car prep, including using the same magnets I always use
I'm assuming that everything will flow as it has during our THSCC events BUT want some input in case there is some procedural thing that I don't know about.
Thanks, Chris
I believe they are still ironing out some details. But it will not work any where near the THSCC events. They are planning on using standard run/work order format.
Usually your run/work will be posted either at registration or early Saturday morning.
For example, let's say they have 4 run groups. If you are driving in run group 1 you would work run group 3 and vice versa. If you work run group 2, you drive in 4...pretty straight forward. Usually, there is a 15 minute course walk between run groups 2 and 3.
You will make all of your runs in your run group. All of AS will be gridded together and make their runs together. That makes it fair for each class. Also is a great social time. Although, as you move up the ladder of competition...the social aspect drops off
The other principles of numbers, course walking, registration still apply. If you can register and tech the night before, all the better. One less thing to worry about Saturday morning.
I am not sure if they are running an impound, usually for NCAC this is not done. At the higher levels, impound becomes the social area. You runs are done for the day and you can relax and chat.
1992 Camaro
CMC#92
