TomFreeman wrote:
Also, I'd suggest the 6pt over a 5pt in a car with stock seats. Without going in to nauseating detail, having to bring the 5pt's substrap up over front of the seat bottom cushion limit's it's effectiveness in an incident. A 6pt setup seems to be a little more optimized for a stock seat car.
I agree 100%. I just went through the whole harness thing for time trials, and unless you're using a race seat with sub-strap hole in the bottom cushion (or planning to have a sub-strap hole cut into your seat), the only reasonable option is 6 pt. I recently installed a Simpson 6-pt harness in my BMW, it clips in/out, and I do remove it and store it between time trial events, mainly because it's not good to leave it sitting in the sun. If you'd like to check it out, please PM me.
TomFreeman wrote:
Though no one has mentioned them specifically, there are the Schrothe 4pts that are DOT certified. I even know of those being used on track in an HPDE setting.
I also have these installed in my BMW (both driver and passenger sides) and use them for autocrossing and for the school portion of the HDPE (I only use the 6-pt for the actual time trial, since I chose to install a 6-pt only on the driver's side). I can tell you the Schroth DOT 4-pts are a whole lot easier/quicker to cinch up than any 5- or 6-pt. Again, if you'd like to check these out, please PM me.
Keith (the guy with the OEM 3-pts, Schroth 4-pts, and Simpson 6-pts all in one car)
