I'll agree with everything that Mike said.
Keep in mind this weekend all the announcers were volunteers (maybe we let David have it as a work assignment since he did so well). Still, that leaves 3/4 of the event with volunteers, often that volunteer was David.
Even with people volunteering to announce, we had problems with workers not showing up and showing up late. If we add 2-3 more workers to the equation per heat, that means we are short 3-4 workers per heat.
If I was in a position of not having a radio, I would have looked for a friendly face nearby and asked, "Hey, can you get my time for me?" THe answer is likely *always* going to be yes. If they are old like Charlie Guthrie, I might have a pen and paper handy so he can write it down
That solves the problem, promotes socializing at the events and might even make you a new friend. That's why we run these events. We are a *social* club as well as a car club.
We're open to suggestions on how to fix this. We were aware of the problem at the event (and before it), but don't currently have a very viable solution. Simply pointing it out to us doesn't help any, however, a constructive proposal on how to fix the problem does help (like your suggestion of having someone radio the results to the post-it person at the finish).
Unfortunately, for a lot of suggestions, we'll point out why it won't work without solving additional problems.
PS: The big display will run all day hooked up to a 12V battery and it's language/connector is a 7 pin RS232 serial port. The JACS box outputs the signal. All somone needs to do is come up with a wireless link in the middle.
