1. At a typical event we run 500-600 runs. Having something print at the bus means that we have a huge number of cars / people who will be visiting after each run. This has the potential of causing a traffic clusterf*ck.
2. It adds another thing to stock, set up, and maintain. We've proven to not be very good at things that need to be stocked and set up regularly
3. It adds a bunch more paper/stickers/whatever that will undoubtedly end up as extra trash or on the ground after the event.
Now with those things said, if someone can come up with a solution for something that prints out at/near the finish that is easy for a driver to grab (think like the airport parking "push button for the ticket" kiosk, then I'd be for it
I agree on point one. As for two, never underestimate the club's ability to maintain something that tells them how fast they went.
As for three, definitely an issue. That's one reason a label-type printer may be better as you can stick them to something.
I don't see any easy way to have a system that can request a printout (push button to get timeslip). But it does appear fairly easy to setup a wireless printer at the finish. Requirements would be:
802.11 Wireless Access Point in bus ($60)
Permanent 802.11 antenna on top of bus ($50, plus labor)
802.11 print server (looks to be about $75 from D-Link)
Label Printer (about $150 plus labels)
12V Battery (about $100)
Power Inverter (about $50)
Now, this is assuming one battery can run the print server and label printer for an entire day, which we don't know. This is also assuming the WAP in the bus doesn't cause too much current draw on the electrical system in the bus, which I don't think is the case, but we don't know.
But if we really wanted to "get geek" here for a second, half of the above solution (the 802.11 WAP and antenna) would allow folks with 802.11 laptops or handheld devices to access T&S data relatively easily, I'll bet. It would probably be pretty easy to setup a web server on the T&S laptop. Then save HTML results to the proper folder on the laptop and *bang*, they get "published" to the web right there at the event. Setup the WAP to hand out DHCP IPs on the "THSCC" SSID and point your browser at the right IP and you have up to date results. Wheee....
Of course, that's a different problem altogether, but if we just had that part, well, I'd be fine without a printer. Assuming we could talk T&S into publishing unofficial results somewhat regularly (heck, I'll bet we could get Vitek to add an option to do this at some sort of timed intervals or something since it's really just a report save type thing).
It's not as good as timeslips for being able to get times while running, but it would be great for between heats and such. And you could see other people's times that way, too. Sort of like iCard, but likely much cheaper and easier for everyone to use since many folks now have 802.11 devices anyway.
