7. "Jim Diesel" is still fast even on Patrice's old tires.
Hey, I learned a few things this weekend myself:
1. Really worn out Kumho V700’s are a *slight* bit stickier than really worn out Michelin Pilot Sport Cups.
2. Putting said less sticky Sport Cups on the rear of a nicely balanced car makes it as loose as a $4 hook**, um, let’s just say it was loose.
3. Even after somewhat rebalancing the car by disconnecting the rear sway bar, making a LARGE shock adjustment and using totally bastardized air pressure settings, it doesn’t help a lick in a straight line when trying to recalibrate my right foot.
4. Really worn out Sport Cups work *much* better when smokin’ hot. Luckily (???), given the amount of rear wheel spin we were getting, it didn’t seem to be a problem heating them up.
5. Watching your co-driver trying to acclimate himself to a treacherous car setup with a sudden 200ft-lbs at the rear wheels of a 2200lb car is somewhat amusing. Needless to say he did a great job considering the conditions and the only person to spin the car all weekend happened to be me. Doh!
6. Hitting the final small cone on course in the midst of a clean 52.4 conservative run doesn’t put you in a great state of mind for your last run.
7. During said last run, after making an awesome drive through to the first turnaround and then running wide 3 feet doesn’t lead to rational thought.
8. You can’t make up for lost time by trying harder at the next gate. While I already knew this, apparently I need a refresher because that was my first thought coming out of the turnaround.
9. Spinning at the very next gate after the turnaround from trying to hard does not lead to a faster lap time. Well, at least I can finally say I spun the car out. I’m convinced the car thought it was my nameless co-driver *cough* Rob Plank *cough* and decided to spin on its own.
10. Sliding sideways through one of Laurinburg’s finest anthills in a convertible with the top down is not highly recommended. Unless you’re in need of a little extra protein…
11. Running out a tank of gas after your co-driver puts 87 octane in it for the ride home is no fun. If I wanted to drive that slowly, I’d have kept a stock Miata.
12. Finally burning through the tank and getting the proper 93 octane in it makes the car much more entertaining.
13. Finally getting your #$@@#$!!! internet service installed at the new house after a nearly 1-month absence and getting caught up on the forums rules!!!
p.s. Anybody want to warm some rear tires for me at next week’s NCAC event? Seriously!?!
