....moving from my gas tank question.....
I had posted a note stating that I now suffer from over steer on the 328 after installing a larger 28mm front bar. My question is to Keith, Mike and any other bimmer folks out there. Since the car is now oversteering, what advice to you have to make it more neutral? The car felt great with the front end planted, just un-nerving to have to fight the rear end from coming around on you.
Any advice? Is the fix as easy as tire pressure adjustments? Everything on the front end is new (from a bushing standpoint) while the rear components have 111k on it. Since there is technically very little I can do for the rear, what solutions do I have?
1. Learn how to drive it.
Most people that have driven my car think it is terribly loose. Every time I have made it a little wilder, I think it's undriveble for the next few events. Then I adjust to it and get faster. And I am about to make it a *little* looser by going up in rear rates 50#.
Having not driven your car, I can't say whether it's beyond uncontrollable. I would doubt it with the stock suspension and just a bar upgrade. I'd love to do a fun run and give you some feedback though
So give it a few events first.
2. Make sure there is NO toe out, front or rear. I'd suggest 0 toe all around. But don't change it until #1 is done! Yes, it's adjustable in the rear.
3. Dial in some rear camber. Yes, it's adjustable. Same comment about #1.
4. Finally, check tire temps. If it's "really" oversteering, rear temps would be much higher. That could be from excessive wheelspin though, but that takes a different approach to correct (ie fix the driver).
