 Post subject: Season Points have been tabulated
PostPosted: Sun Oct 31, 2004 9:14 pm
Season Points should show up on the web shortly. Here are a few of the things you need to know.
1) Only members count. Not a member? No year end trophy.
2) You must run a minimum of 5 events to qualify for a year end trophy.
3) You are only eligible for a trophy in the class you ran the MOST events in.
4) If you haven't run 4 events, then it's too late.
5) We drop your worst two events when calculating the final points.
I'm sure I'm forgetting things, but yall should get the idea.
I'm counting on yall to audit this thing for me!
PostPosted: Sun Oct 31, 2004 9:35 pm
Does our rescheduled Sanford event still count as a points event towards season points?
Graham
PostPosted: Mon Nov 01, 2004 12:02 am
You gotta race the truck
So which class do I get a year end trophy for?
By points I am top 10 finish in 3 different ones :D
91 Jetta GLI STS/DSP 111
85 Porsche 944 ASP 11
PostPosted: Mon Nov 01, 2004 12:14 am
I killed the wabbit
PostPosted: Mon Nov 01, 2004 2:04 am
waaaah...Jake is #1 in HS by 8pts and he won't get a trophy no matter what
www.ncvw.org
1997 BMW M3 3.2L - BS for now
PostPosted: Mon Nov 01, 2004 7:45 am
Graham
Yes.
 Post subject: how will it all end?, season points-silly season
PostPosted: Mon Nov 01, 2004 8:29 pm
Just playing with a few scenarios...
S-Stock: No trophies
A-Stock: Looks like Miles has it. Even if he doesn't show Graham can only tie in points, but the tie break goes Miles' way. The Dark Horse is Dan Ecclestone. If he bums an A-Stock ride and wins AND Miles doesn't come in 2nd, then Dan gets the season trophy.
B-Stock: Rick Butters clinched it a while back.
C-Stock: Chris Peterson will clinch with a 4th palce finish. But, she has to show up... 2nd place is a dead heat between Dustin Fredrickson and Brian Whalen.
C-Stock Ladies: Malia Fredrickson wrapped it up last event.
D-Stock: Bill Martin has locked it up, there is a very tight race for 2nd, it's toss up between Rodney Wright, Mark Musser and Sally Johnson. Rodney's the long shot, but it could happen. Sally just needs to keep it close to lock things up. A win would guaranty 2nd place for Mark.
E-Stock: Jim Pastorius needs a win. If Jim P. wins Sunday, I think it will be a tie, even with the tie-breakers.
F-Stock: Todd Breakey, unopposed.
G-Stock: The top 3 are too close to call it, Donna Frank and Lee Williams are in a must-win situation, where-as Charles Frank just has to beat Donna.
H-Stock: No trophies
ASP: Robert Plank, unopposed.
BSP: Bill Gratton is a lock if he just shows up for the event. He doesn't even have to run BSP (Bill hasn't run 5 events).
CSP: Brad Mackey almost has to win to catch Jason Pancera. If Jason is a no-show, then Brad only needs 2nd place to catch up. It's too close to call at this point. I suspect Les Davis might be playing the spoiler.
DSP: Mike Whitney (duh). It's possible for Shane Kaihler to catch Jason Mauldin for 2nd, but not easy. The real battle is between Charlie Guthrie and Tonya Mauldin for 4th/5th.
ESP: Vincent has wrapped it up. Marcus McRae might catch Randy Melton for 2nd place.
FSP: Jim Wray has the season win IF he shows up, otherwise it goes to Jerome Pollard (Starlet) unopposed. If there was a clerical error and Maurice Parker really did pay his dues, then he's in the thick of things for the victory.
AP, BP, DP, FP: No one
CP: Chris Walker, unopposed.
EP: Kurt Bishop, unopposed.
AM, BM, CM, EM: No one.
DM: Phil Wehman, unoppsed.
STS: Chris Brown. Richard Casto has locked up 2nd, unless Wes Eargle decides to bring his Contour out for one last hurrah, then it's a toss up between Wes and Richard.
STX: Keith Quistorf has it, unless Brian Herring borrows an STX car for the last event and wins, then it might go to a tie-break. Les Davis will be 3rd.
STXL: Stacy Herring (unless she wants the STUL trophy instead)
STU: No one
STUL: Stacy Herring (see STXL)
ST2: Doug Jackson, IF he comes to the event (needs one more to qualify).
SM: no one.
SM2: Patrice Bousquet. 2nd place is a dead heat between Kathy Gleason and Gordon Taylor.
Tire: Closest class out there. Jim Williams, Marcus McRae, Matt McGrain, Michael Westerfield and Stephen Westerfield all have a shot. If Jim Williams can make it to the event he'll probably pull off the season win.
Pro: Tom Hoppe didn't pay his dues, so he ran away to a season-nothing (I suppose that SCCA jacket might be worth something). Kevin Allen is in a commanding position going into the final event. Shawn Whipple is in a MUST WIN situation, but he needs help. If Kevin finishes 2nd, then he still clinches it. If Shawn doesn't take first place, then Kevin wins even if he stays home.
Eric Peterson can't get first, but he's still in position to knock Shawn back to 3rd place.
 Post subject: Re: how will it all end?, season points-silly season
PostPosted: Mon Nov 01, 2004 11:20 pm
I prefer to say that I locked up the championship after the 5th event thank you.
My co-workers don't need to know anything different. :lol:
PostPosted: Tue Nov 02, 2004 12:05 am
Excuse me?
I ran ASP last event and will do so as well this event.
I actually think Robert should give me ther trophy since I make it a class of 2 and he doesn't get bumped :D
PostPosted: Tue Nov 02, 2004 8:08 am
Excuse me?
Still unopposed since no one else is eligible for a trophy. Bumping doesn't influence season trophies either, the bumpee still gets 9 points no matter where they land.
PostPosted: Tue Nov 02, 2004 9:26 am
:D I will be in Chicago for a romantic get away. Who would have thought I would pass up a THSCC event. I must be getting soft.
At least the MR2 will take first place. By the way, if you want a real legal sportscar that can get you a first place trophy, it only costs you $6500. That includes $2000 worth of real cheater tires...Hoosiers.
I can atest to the fact that the car makes you a winner, attracts beautiful women, prevents hair lost, reduces your weight by 30 lbs. And the Hoosiers are better and cheaper than Viagra ;)
PostPosted: Fri Nov 05, 2004 4:27 pm
Won't Malia and I be tied? I don't think she'll be there Sunday.
PostPosted: Fri Nov 05, 2004 10:12 pm
Don't think so. While Malia won't be there this weekend, it'll count as one of her drops and she won't lose any points, thus putting her 3 pts ahead. This assumes we can drop 2 events, as the results sheet seems to indicate.
PostPosted: Sat Nov 06, 2004 6:54 am
Dustin is correct. Only your best 6 finishes count towards the season trophy.
