markmerrill wrote:
You see why I balk a bit? I think I'm at over 2k for shipping + wheels + tires + tpms + tpms tool for swapping the car between tpms sensors.
Quite a bit more than I'd hoped to spend. And that's with an offset of 50 not 55 (the 55 offset wheels are ludicrously expensive).
The car came with 245s on it. 255s... and with 5mm further out from just the rim, will it fit? I'm finding it difficult to search for due to folks talking about the STI and many more interested in the look than in performance. I did find some folks saying that you tend to lose feel if you go too wide?
This looks possibly promising... just a bunch of money to "hope" about. Would probably need to join a forum and actually ask the question unless one of you fine folks has experience with this car/wheel combination.
http://www.willtheyfit.com/index.php?wi ... offset2=50Yes, 255s will fit on an 8.5" wheel. BS S2000s do it all the time. As to whether there is a rubbing issue--no idea, so defer to others who may have tried that fitment on your car. I have heard some say they "lose feel" when they go with a wider tire, but they also end up going faster, so...you have to experiment to find out. In re TPMS--my GH WRX had an ECU that was TPMS-agnostic and didn't care if the light was lit or not. Has something changed where TPMS causes nanny-interference in the newer models? If not, just put a piece of tape over the annoying light and press on. It will likely be cheaper to just swap out tires in the offseason and stay with OE wheels than have two sets, even if you have to have the TPMS rebuilt on occasion.
As for wheels I failed to look at 50 offset options--whew! Those are more reasonable with Enkeis in the $220 range. I would join NASIOC and cruise their FS/FT forums for options. You could always join the local/regional FB Subaru community, but if it's like the S2000 ones the signal:noise ratio is pretty low-- so be patient.
1972 Datsun 240Z-- resto pics at
http://picasaweb.google.com/srcartermd2007 GPW Honda S2000-- STR 86
