 Post subject: 2016 Season Points Standings
PostPosted: Sun Apr 10, 2016 12:28 pm
The 2016 Season Points Standings are online.
It's a little early to start commenting on specific battles, but it definitely looks like there will be some good ones this year.
As usual, let me know if you see any issues with the results.
03 Nissan Altima
02 Honda S2000
 Post subject: Re: 2016 Season Points Standings
PostPosted: Mon Apr 11, 2016 1:50 pm
I just noticed a mistake in my points formula. It's awarding 10 points for first place in class instead of 9 as it should. EDIT: fixed now
03 Nissan Altima
02 Honda S2000
PostPosted: Mon Apr 25, 2016 8:40 pm
Updated with results from points event #3
03 Nissan Altima
02 Honda S2000
PostPosted: Wed Apr 27, 2016 8:20 pm
very nice :thumbsup:
The fleet: 06 Legacy GT 5M; 08 C6 Corvette Z51; 17 Camaro RS 'Fifty' turbo; 17 Impreza Sport; 13 Outback Wagon
PostPosted: Sun Jun 05, 2016 8:59 pm
Updated with results from our Jimmy V points autocross events #5 and #6
03 Nissan Altima
02 Honda S2000
PostPosted: Sun Jul 17, 2016 10:19 pm
Updated with results from the two state autocross tour this weekend
03 Nissan Altima
02 Honda S2000
PostPosted: Sun Sep 18, 2016 2:45 pm
I just finished updating the season points standings spreadsheet with results from our points autocross #9 at cary towne center.
I lowered the planned event count from 12 to 10 to match our event calendar. I also found and fixed a bug in the drop-two-worst-finishes code; it was failing to sort finishes correctly prior to dropping, so what it ended up dropping were the last two events, and results from #9 were triggering the bug. All fixed now!
03 Nissan Altima
02 Honda S2000
PostPosted: Thu Nov 17, 2016 2:00 pm
I know folks are busy, but will we have the results from the NCCAR event and the season points standing available soon? Just curious, I'm sure other drivers are anxiously waiting as well. :thumbsup:
PostPosted: Thu Nov 17, 2016 3:02 pm
Results from the NCCAR event are up already.
2017 Autocross Chief of Tech
2000 E Street Miata
2015 Fiesta ST (Wife's ride)
PostPosted: Thu Nov 17, 2016 3:38 pm
The season points look to be up to date too!
PostPosted: Thu Nov 17, 2016 3:43 pm
Be careful how you read the points standings. I would hate for anyone to be disappointed because they were mislead by the points total. When determining the class positions, we use the sum of your 6 best finishes, you must have attended at least 6 events, and you must be a paid up on your club member. This way if you miss an event or two, you will not be kicked out of contention. The class results are based on how well you drive, not only your attendance record. :soap:
Mike Miller
AutoX VP 2016/2017
Just a C Stock Miata DD
Mazda Speed 3 Family Car
Corvette Z06 Toy
PostPosted: Thu Nov 17, 2016 5:38 pm
I don't see the last event in there, I know because I ran ES but my name isn't on any ES results :)
2000 E Street Miata
PostPosted: Thu Nov 17, 2016 5:53 pm
I never saw a thread on that, but good to know they are up. Thanks all!
Edit: I see that my first bad time is still listed and my final run isn't listed. I should have had 7 runs total with the first run of 103 seconds tossed due to a red flag. Did that last run get lost? I was really hoping I had made it into the 85's, that last run felt good... Would someone be so kind as to check on that please?
PostPosted: Fri Nov 18, 2016 5:00 pm
The formula in the "Season Pts" column accounts for the drop-2 rule. Minimum attendance threshold and club membership aren't considered. The next column over lists the driver's participation in the class, which will cover drivers who ran the same class all year and would hence be eligible for a trophy. Membership is kind of a hassle to look up for so many people, so the spreadsheet intentionally defers that until we have a short list of likely winners.
I'll look into this over the weekend.
Edit: the story checked out. Your 103 gets a rerun, and now your 85.294 shows up as your fastest run. Looks like it had no impact on CAM class or top 10 raw/pax results
03 Nissan Altima
02 Honda S2000
Last edited by Carlton Whitehead on Sun Nov 20, 2016 12:13 pm, edited 1 time in total.
PostPosted: Fri Nov 18, 2016 5:06 pm
The new spreadsheet for this season has a lot more automation than previous years. However, I still have a manual process to add drivers to the class sheet after their first time running in a given class. I didn't see any need to do that after this event, since a driver running only one event in a class wouldn't be eligible for a season trophy unless they specially requested it, at which time they can be added, like I see Francis did for you.
03 Nissan Altima
02 Honda S2000
