The updated results are online.
While the event was underway, AXware was using a class file (containing PAX definitions) from 2014, so any PAX times shared during the event (such as via instant Results, which was conveniently offline due to hangover) would likely have been incorrect. Before we announced results at the end of the day, I reconfigured AXware to use the new 2015 class file and forced it to recalculate all PAX times. Unfortunately, the 2015 class file didn't contain a CAM class (because SCCA broke it up into 3 different classes each with suffixes), so AXware failed silently and calculated CAM class registrations with a 1.0 PAX. Apparently, AXware's class validation is hooked up to import and registration, but not class file changes. Lesson learned. Because of this correction, the results now show Chad and Austin Culbertson taking first and fourth place, respectively, in Novice class. Congrats guys! Also, I'm very verry sorry for this mistake!
I had heard some other people suspected that the results weren't showing their PAX times correctly, so I
manually verified a significant subset of the PAX results, and everything looks OK. If you find anything wrong, please let me know.
