When I did circuit crosses at CMP with CCR they basically made chutes through the turns that dictated a very slow line (early apexes that meant a decreasing radius turn) or a gate way off-line before a turn and then a very tight slalom on the back straight to keep speeds down. The speeds were still uncomfortably high and my autox/street brake pads were cooking at the end of each run.
This may not be visible on mobile due to some copyright infringement
http://www.youtube.com/watch?v=N5ZIPu1GwF4&t=5m18s(70mph is at the top of the giant MINI speedo, btw)
I dont know how to do it better at a sweeper track like NCCAR. The offset gates were designed to keep speeds in check through the long turns and the most technical parts (lane change, high-speed offset slalom and pivot cone) were all on straight sections of track with adequate runoff room. We drove the track at 85% (and unfamiliar cars) on Friday night and adjusted it several times to ensure reasonable speeds for given runoff and a nice flow.
There's only so much a course designer can do.. the rest depends on the participants to not overdrive their abilities & equipment. Given we all had 6 runs and each of the drivers that went off continued to run afterward, blaming the course designer for going off or for any portion of the course being designed to catch drivers off-guard seems a bit far-fetched to me. If those drivers felt the course was unsafe it was their responsibility to alert a steward and stop running on it themselves. If something caught you off-guard you might want to rethink your course walk habits.
I'm not being defensive. It wasn't my design. I was just putting cones where I was told to. I'm also not trying to start or finish a fight. What would you folks have done differently? Another lane change element instead of the offset slalom?
