Post new topic Reply to topic  [ 164 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: Points Event #2, NCCAR May 10 (Sat.)
PostPosted: Wed May 14, 2014 1:03 am
Chuck Branscomb wrote:
In my senior year, 1981 *terminals* showed up, amazingly, which at first simply allowed you to key in your 80 column/line program and submit the batch job to run and print.
In my senior year, 1981 (at UNC) we started finding the CRT terminals in the basement of Phillips Hall occupied by NCSU students who were as desperate as us to escape the tyranny of the IBM Model 029 keypunch. Then I discovered there was a lightly-used terminal room in the Business School building next door.
PostPosted: Wed May 14, 2014 1:42 am
Art,
Keith really helped me out by pointing what should have been obvious to me (this of course would be no news to my wife). Getting into 3rd early for the final turn onto the main straight as I was dealing with a super twitchy car at speed through that jink-slalom. I had to upshift to third somewhere along there (2nd runs out at 68mph and I was on the limiter by the jink-slalom devil), but short shifting and getting into 3rd sooner was the key.
He also said to try 2nd out of the turn-around. Even though it was a super slow exit, there is plenty of torque to reach the tire's limits relatively quickly. I was wasting time trying to manage wheelspin/drifting in 1st and then having to do a 1-2 upshift mid-late-turn on the VDA. Just staying in 2nd solved those "fun" issues and allowed me to focus on "tight is right" and trying to stay right on the limit around that left.
Thanks Keith, I really appreciate the discussion. Thankfully you didn't follow up the 3rd gear early discussion with "isn't that obvious", or "how long have you been doing this again?" :D Oh and thanks also for the tire pressure tips.
Art,
Are you getting lots of rollover with the Rivals? You might want to experiment with lower pressures. I'm running 275/35-18 all around on 8.5/9.5 wheels, and the 275s up front, while pinched a bit, are working well (I think). I had been running hot pressures of 38/36, but at this event I went down to 35/33 after talking with Keith about what he's running. I still had no significant rollover issues at those pressures which you can't fathom how on a camber challenged strut car with minimal adjustment (i.e. I have -1.4 up front) how happy that makes me. :) (after years of E46 pain in D-stock years ago).
Also, you might want to consider trying 275/35s all around on your 8" wheels? I have friend in FL who is actually running an E39 M5 beast in F-street (M5 has 8"/9.5" wheels), and he went with the 275s pinched up front year and is doing really well with the car, and his front tire wear is much improved (the M5 has ZERO camber adjustment from the factory and is stuck at -0.5, so he's dealing with that fun issue).
Like I said in my earlier post, I think I would have been better going to 3rd even earlier than that. The problem is that I seem to have trouble with accidental 2-1 upshifts when I'm in a hurry, or at the very least finding the 0.0000000000001 mm wide wall in the gate during a hurried 2-3 upshift. I like to think that's due to the engine/transmission rotating on the soft stock mounts under load, but it might just be incompetence.
4.6 liter mod motors don't make much torque below 3K, so I think 1st was the right gear for exiting the pivot. I was generally patient enough to control understeer and wheelspin between the pivot and my upshift just before the last slalom.
When I was tire shopping last year, the opinion of this forum and the Tire Rack salesman was that you should not pinch Rivals. Who knew? If nothing else, the 245/40-18s are slightly taller than 265 or 275/35s, so in theory I have 2 mph more in 2nd gear. They're hardly wearing at all after 4 events, just a little on the shoulder. I'm running about -1.8 degrees of camber, and my wheels are 8.5 inches wide, dammit! :)
(As an aside, I managed break both my 10 year old Harbor Freight torque wrench and a 22 year old Craftsman socket while changing back to my street tires at the end of the day. I know what to do about the socket. What brand do you guys recommend for 150 lb-ft torque wrenches these days? )
PostPosted: Wed May 14, 2014 7:46 am
Art - Since I'm still using an almost 40 year old Craftsman torque wrench I don't know what is an accurate but not $$$ option these days.
FYI there is a good chance I'll have a 4-5/32 tread depth set of 265/35x18 ZII's for sale this summer when the tread depth is too shallow for comfort to drive to/from Lincoln. Either before or after the Wilmington Pro and Tour depending on tread depth.
Dick
PostPosted: Wed May 14, 2014 7:58 am
Chuck - Do you have any "measured" info on the grip and/or responsiveness of pinched tires at lower versus higher pressures?
Sam Strano drove my car which I assume has a heavier front weight than yours at a medium grip site and settled on 40 psi F/R for 265/35x18 ZII's on 8 inch rims. ZII's are supposedly at least as "pinch tolerant" as Rivals. I have -1.7 deg negative in front and, of course, 0 in back.
Art - Since Rivals and ZII's apparently have about the same grip you either drove a LOT better than me (likely) or you weren't giving up significant grip to my 265's. That said, my car without driver weighs about 3600 lbs. What does yours weigh?
PostPosted: Wed May 14, 2014 8:02 am
You've got the engine/tranny movement under load too? :) I have to be careful with a 2-3 upshift if I try it under heavy cornering loads too.
Hey, same here except I'm dealing with 4.0 liters. :( :shock:
You'd be fine with 275/35s I would bet (also, they're the same diameter as the 245/40). I didn't realize you had 8.5" wheels. What I noticed from switching from 245 to 275 this season is: (1) better braking, especially at high speeds at the Peformance Center track (i.e. 100 to 30, well come to think of it we had that this weekend too! Thanks Patrice!); (2) tail is much more planted under heavy power from apex onward -- when the M3 hits its meaty powerband between 6000-8400, the 275s are really helping out back (9.5" wheels back there fwiw); (3) there is no "floppy" feeling to the tires, transitions are maybe just a bit less tidy however; (4) ideally, I'd like to have 10" wheels all around. :)
Here's the link below to sccaforums I mentioned before where Jay is running 275 Rivals pinched onto 8" wheels up front (versus 245 RS3 last year which his M5 destroyed in short order) and 9.5 in the rear. He's having great success this year as this is a much better setup for his car (and he's PAXing that 4000lb beast near the top of his region :o ). His tire wear is hugely better also, so he's been very satisfied with this setup so far. This guy is a great driver having just started autocrossing recently.
http://www.sccaforums.com/forums/aft/445010
PostPosted: Wed May 14, 2014 8:09 am
Dick,
No, I'm just (and always have been) a hack driver. So take my "thoughts" as just that, opinions, that may or may not be measurement-backed in fact. The engineer in me has serious trouble nit-picking tests that people do (where they don't hold so many variables constant) through which they draw conclusions they seriously believe "since they measured it." I would like to participate in some pure testing someday however. If I get into stuff like a Solo Storm setup, I'll go whole hog into it though. :) At the moment, I don't know what I'd do with that type of data in the very few short minutes between runs.
PostPosted: Wed May 14, 2014 8:27 am
The 2-3 upshift on the s197 mustangs is a well documented issue. Under load, you simply can't make the shift into 3rd gear due to the engine movement and the dampening bushings on the shifter. I can't tell you how many 2-3 shifts I've missed. Got tired of the aggravation and swapped shifters. An after market shifter like an MGW will solve the shift problem, but effectively moves Art out of stock class, and while I'd love to see Art come over to the new CAM class, I think he'll forever stay stock.
PostPosted: Wed May 14, 2014 8:38 am
Dick,
Shucks. I was hoping there was some good solid data. Ditto on the tire spraying question. I barely looked at my SoloStorm data between runs other than to double check that it had gotten the runs and to verify the rev limiter time before I decided to shift to 3rd after the lane change. Regarding the tire spraying question, my DL1 data shows essentially no lateral or longitudinal max grip changes between runs at either NCCAR or VMP the next day (where I drove much better). ZII's are supposed to need spraying or you die . . . based on their personal experience so I don't know what the actual variables are. I don know, however, that when I'm trying to go faster the tires somehow are more likely to slide . . . maybe because I'm actually going faster than they can handle cold or hot? :(
PostPosted: Wed May 14, 2014 8:41 am
How fast do you guys in higher horsepower cars figure you were going entering the pivot cone on the pad?
I have no idea how fast I was going in the ES Miata. Coming out of the offset / box / lane change looking thing, I short shifted to third gear. I went down the hill into the left hand sweeper-y-thing full throttle. Other than a minor brake brush to tuck the nose in at the bottom of the hill where that one gate tightened up on us, I was full throttle all the way out of there, too. Full throttle, early in third gear, in a Miata is a lot less interesting than it was in an S2000. And even less interesting than it would be in a Mustang or an M3.
In other news, if anyone has an unused camera setup they'd like to sell, hit me up. I nearly choked when I saw what Go Pro cameras sell for. I don't want to look at video quite bad enough to drop $400 to do it.
I see Dick posted something about spraying tires. I'm on ZIIs as well, and didn't spray them. For a lot of my runs, the car started off an absolute sweetheart, and by the end, it felt like maybe one of the tie rods was broken. :) I was told spraying them would help a lot. Could be I'm just a hacky driver.
PostPosted: Wed May 14, 2014 8:48 am
Karl - On my "best" run DL1 data shows a top speed of 73 when processed at 5Hz and 71 when processed at the more accurate 20Hz. SoloStorm's software but using DL1 data shows 71.6 mph.
Mid fifties through the offsets with very little throttle there (big soft car with tons of power versus grip). I went from about 58 to 71 in about 2 seconds and 200 ft in 3rd gear which is good for pushing 100 as I recall. Rpm for the acceleration was 4K to 4.8K. Rev limiter is 6.8K. Forward acceleration was about 0.3 g's
Last edited by DickRasmussen on Wed May 14, 2014 8:56 am, edited 2 times in total.
PostPosted: Wed May 14, 2014 8:51 am
Karl,
I bought the new GoPro white edition for $200. It's by far "good enough" for what I use it for, so I saw zero need to spend more. It works fine, wifi controlled from my phone works (most of the time), etc.
PostPosted: Wed May 14, 2014 9:06 am
Karl,
Karl,
I have gen1 GoPro you can have for cheap....like $100? Or, this camera I got from Amazon has been excellent:
http://www.amazon.com/Liquid-Image-727Y-Mountable-Camera/dp/B007M4X3PG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1400072615&sr=1-1&keywords=lic+camera
Can't make the meeting tonight as I have the second shift, but can deliver to the next event if needed.
PostPosted: Wed May 14, 2014 10:23 am
Online
Karl, not a high horsepower car but, on my last 2 runs going into the pivot cone I saw the shift light flash in 3rd but never hit the limiter. I tried it out of the way home and it turns out that the shift light starts flashing at about 78mph indicated. That was shifting to 3rd as soon as the car settled after the lane change with only a couple of lifts to get around the 2 pinches to the left and then flat through the wiggle slalom.
PostPosted: Wed May 14, 2014 10:49 am
Hrm. Maybe I was slowing down for those pinches more than I think I was.
PostPosted: Wed May 14, 2014 3:13 pm
I was going 82-83 mph when I started braking (pinging off the limiter in 3rd).
