I think someone wise in the club made that prediction earlier this year. Wasn't equitable across classes...
That wise person should be president....
With the SCCA road tire classes it was potentially mitigated by separate classes for Front, All Wheel, and Rear but really didn't address the high/low power cars in the same class. Rick will have fun . . .
Honestly I think those 3 classes are worthless because clearly an across the board 2.5% PAX discount doesn't work for the spectrum of cars regardless of drive type. Hell, even within the SAME class, it isn't fair but with a full classing restructure next year, it might get taken care off.
Example, even amongst outgoing SS cars, the Elise and Corvette are two top contenders (both RTR, but who cares about the A/F/R.....said James Milko...). The Corvette is going to be terrible next year on street tires since in the ESPT categories, you don't really find much 300+mm tires and even then, the Corvette has so much torque it'll be hard to get it down on street tires whereas the Elise might find it quite comfortable to perform on street tires and hence in a Super Street class, the Vette might wither away (yes I know there is a Super R class that they are talking about, but that's not relevant to the convo). So even within the old Stock-R classes, there is inequity to compare all of the same cars to each other going from race rubber to street tires. Then enter the fixed 2.5% PAX discount across all stock classes, which makes even less sense. For Street category next year and onward, I'd hope that each class gets A) an appropriate PAX reduction based on the type of cars in the class (ie FS and SS gets a big discount for running street tires and HS/GS or CS or ES get relatively little discount and B) the Street classes cars likely can't be a 1-1 with the 2013 Stock classes since going from r comps to street tires is going to limit both the size of tire and availability of said size as well as the feasibility of putting decent power down on the smaller tires.
