Post new topic Reply to topic  [ 117 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: Street category
PostPosted: Tue Apr 23, 2013 8:45 am
JamesShort wrote:
JohnByers wrote:
Refresh my memory. Gripe was?
Double sway bars.
Refresh mine too. Why is that so bad? I've always thought it made mechanical sense to allow people to run a balanced suspension. As it is now, there are crazy things people do that create an extremely mis-balanced car that is only good at autocross and only due to the transient nature of the sport (i.e. massive front sway bars that break suspension mounting points/control arms/etc). If it was me, I would make the rule allowing front and rear replacements, AND specify a maximum change in swaybar diameter, in percentage terms, from the factory design. Oh well.
PostPosted: Tue Apr 23, 2013 9:10 am
Arthur McDonald wrote:
I was wondering if my favorite stock category allowance would survive the transition to street category.
In fact, it's been liberalized quite a bit.
proposed Street Category 13.8.F.2:
Camber bolts may be installed and one bolt’s mounting point(s) on the strut’s lower integral mounting bracket
may be slotted. Caster changes as a result are permitted.
Existing Stock class rule 13.8.E:
If offered by the manufacturer for a particular model and year, the
use of shims, special bolts, removal of material to enlarge mounting
holes, and similar methods are allowed and the resulting alignment
settings are permitted even if outside the normal specification or
range of specifications recommended by the manufacturer. If enlarging
mounting holes is specifically authorized but no material removal
limits are specified, material removal is restricted to the amount necessary
to achieve the maximum factory alignment specification.
Art, the previous stock rule kind of sucked since VERY few cars out there have MFG offered camber compensation instrumentation (shims, bolts etc). The new one is awesome :).
Chuck, I think we talked about this before but it's just that with 2 bars you can get not only a car that has minimal roll rate, but also one that is balanced. However, I think it will make it difficult and expensive to be competitive because, naturally, running monster bars only works on some cars due to geometric constrains and needing to by insanely large sway bars with custom mounts and endlinks that will destroy your subframe and possibly suspension arms is just going to be a hassle and large expense which I think is going in the opposite direction of what the Street Category intends. I think the front or rear bar change a few years back was quite nice though.
PostPosted: Tue Apr 23, 2013 9:22 am
Oh, yeah, hey you gotta give me a break on memory. :D Seriously though, I think the SCCA is doing a great dis-service by allowing unlimited swaybar dimensions that can result in severe and potentially dangerous damage to other parts of a car's suspension. How about a car that was used with a monster front sway, then it was removed and sold. During the usage, portions of the front suspension were stressed well beyond their endurance limit and perhaps even plastically deformed in some sections and/or started fatigue cracks that all go unnoticed. That risk is then sent downstream to future owners. It's truly insane to allow this stuff imo, but I guess I tend to be a party pooper by pointing out stuff.
Hence my kingdom would have a rule imposing a maximum percentage change in diameter (oh, and allowing both bars to be changed).
I'm looking at this from a high level management view where you see something going on in your company that "everybody" is accepting until somebody with authority has the insight to stand up and put an end to the practice.
PostPosted: Tue Apr 23, 2013 9:43 am
Chuck Branscomb wrote:
From Hollis blog:
Round two of GRM tire testing is complete. Round 1 is in the June issue, which is in final stages (May is in the mail now), and features ZII vs Rival vs Toyo R1R on concrete on an STS CRX. Round 2 is RE-11A vs Rival vs Toyo on asphalt on an STS CRX.
Round 3 will feature 225 Rival vs 225 RS3...battle of that unique size.
Chuck posted this preview a while ago, but Emilio from 949racing (Miata shop) posted some info about his experience with the Rivals at the track last night. Mind you, this is track and not autocross, but there is still a bunch of good info to take from it.
Emilio on miataturbo wrote:
We had the chance to run the 225/45/15 Rival on Buttonwillow 13CW last Sunday. Car was our 95R street project car. Xida 700/400, 15x9's, 140whp, 2550# (with passengers all day). Ambient was 75~85° with track surface temps of 93~106°. We have run this car with RS3's on several different tracks and weather conditions. Very familiar with min corner speeds, braking points and overall feel of the RS3 on 13CW in particular. No A/B testing done against the RS3's Sunday but some impressions stood out.
Lateral grip
SOTP, the Rival seems to generate about the same peak lateral grip as the RS3. The difference was that the Rival would still generate useful grip when well past optimum slip angle. More like a race tire than the RS3 which prefers small slip angle and loses grip more rapidly with large slip angles. This made the Rival easier to drive and allowed a few "toss and catch" entries into double apex turns that were a touch faster than the slight lift the RS3 required in the same spot. This ability to generate useful grip at large slip angles made them feel more like race tires than any other feature.
Steering
Response and feedback were, like the RS3, very good when the tire was lightly loaded as it would be entering a turn at full throttle. The noticeable difference was under straight line or heavy trail braking where the Rival communicated available grip and slip angle much better than the RS3. The RS3's can get a little numb under heavy trail braking. So unloaded they steered about the same. Transfer weight onto the nose and the Rivals talked more. Overall I would rate the steering response and feedback as very good.
Braking
This is where the Rival is significantly different than the RS3. The RS3 has earned a reputation as a tire with braking that does not quite match is stellar lateral grip. The Rival had noticeable better braking grip and feedback compared to the RS3. Of note is the RS3's characteristic of requiring the driver to transfer weight onto the nose more carefully while the same car/driver on Rivals could reach peak line pressure much sooner without locking.
Temp range
Since we were not conducting A/B testing that day, data collected was minimal. Peak temps were only in the low 170's even after a full session. We did see that the Rivals lap times stayed consistent even after several laps at full speed. This is rare for a street tire. Most street tires have slightly heavier casings and more tread mass than a race tire so they tend to not shed heat as well as a race tire. This typically manifests as the street tire being fastest on it's first hot lap. While there was some drop off late in the session it was less than .6s on a 2:05 course. This is excellent for a full tread tire. The indication here is that the tire sheds excess heat very well, possibly better than most other tires in this category. My guess is that autocrossers with a co-driver will fare better than solo drivers on this tire. We did not run the tire in the morning while it was still cold so I can't comment on cold performance. We ended up with about 35psi hot which compares to 29~34 psi we usually run with R compound tires.
Overall, the RS3 feels like a really fast street tire, having a narrower range of optimum slip angle and weaker braking than a true R compound. The Rival in contrast, felt quite a bit like an NT01 (R compound) with about 5 heat cycles on them. An educated guess is that the 225/45 Rival would be less than 1s slower than a 225/45 NT01 on a ~2:00 road course, everything else being qual. That is just astonishing to this driver. A 200 treadwear (grain of salt) that can nearly keep up with medium compound race tires for a full track session.
I could dig a double sway bar with a fixed degree of increase in size (fixed percent? fixed diameter change delta?). This means the market for hollow bars would close up though :).
PostPosted: Tue Apr 23, 2013 9:59 am
I would say that the rule would have to be percentage based to make sense. Something like "maximum bar diameter may not be greater than 20% larger than stock". Something like a 24mm bar would then be allowed to increase to 28.8mm. Given that stiffness for a solid bar varies with the 4th power of the diameter, this example results in a bit over 100% increase in roll stiffness, so maybe even make that diameter percentage change allowed a bit smaller than that.
PostPosted: Tue Apr 23, 2013 10:03 am
Yep, though it might also be reasonable to allow rounding to the next highest millimeter or 1/16th of an inch. 25% increase in diameter would be a 144% increase in roll stiffness....so 20% is probably more reasonable.
PostPosted: Tue Apr 23, 2013 10:17 am
Thanks for posting that Andrew. I can relate to just about everything this guy has said -- pretty amazing correlation with my thoughts on the tires.
I just got back from an "autocross" at the BMW Performance Center where Jackie and I co-drove the M3 on the Rivals, so I have a lot more internal data now. The track is super fast with almost no cones hence the reason I put autocross in quotes. Top speeds in the M3 reached close to 100mph at a couple of places, so this was more like a time trial especially since the course was about 1:30 long.
First takeaway is that I do really need the stagger fitment in tire size or at the very least larger tires all around. I had no choice though to date since the Rivals in the larger size I need won't be available until June. The power on oversteer was ready and waiting anyplace on course, and with a more appropriate rear tire size, I could have been putting down power better no doubt (I'm on 245s all around instead of having 275s in the rear).
I've done this event four times in the past 6 years, each time with the M5 on NT-01s. Hence my thoughts comparing the tires were strong during the event, but since the M3 is so different than the M5, it isn't a direct comparison of course. I felt that maximum braking was really close to the NT-01 perhaps just a tad weaker if anything. Turn-in response seems much more direct on the Rival (remember there is a car issue at work here too though), and I feel like I can tell what the tire is doing much better than the NT-01. Accelerating traction seemed as good or better. The Rival feels "cleaner" than the NT-01 all over the track which I guess simply means it is communicating to me all the time in a better fashion.
I identified with his comment about being able to throw the Rivals into an element and use high slip angles as I overcooked one very slow section a couple of times, knew it at the time, and just cranked in steering angle. They stuck better than I expected, bled off speed, and then I was on the throttle rotating the tail on corner exit. Not the fastest way in this case, but I had in the my mind being off the course with NT-01s under me right then...
We did 21 runs on that ~1:30 course Sunday, so I have some wear on them now. They are still holding up very well though even though I only can get -1.5 camber up front on this car (stock class). I'm looking forward to the larger sizes in the future, but I'm going to have a decision point of what to use then (245/275, 275/275).
Oh, I was doing some instructing and giving rides to people, and Jackie overheard me telling a guy all about the Rival after a run when he asked about the tires on the car -- she said I should be on BFG payroll or something. :D I'd be happy to just accept free tires though, so I told her to work on that for me.
PostPosted: Tue Apr 23, 2013 10:21 am
This has been my sneaking suspicion for some time even with the RS-3. Even though I have not seen a comparison, I would wager that in an autocross setting the Rival might actually rival the NT-01 in the lower temp ranges. It looks like I can get at least 1 more event out of the NT-01's, but after that, I look forward to finding out :D
PostPosted: Tue Apr 23, 2013 10:27 am
Chuck, I am trying to resist the temptation to order a set of these until AFTER the Fayetteville event 5/5...you are not helping me here!
PostPosted: Tue Apr 23, 2013 10:28 am
The R-S3 will match lateral grip with a tire like the NT-01, but will fall behind in braking and acceleration. It seems like the Rival "solves" those issues and likes a larger slip angle to boot. The only two things I can think of that can be bad are the water dispersion/wet performance and tire life/heat cycled performance.
It really seems like the Rival has set the bar higher for this round of summer tires. It's unfortunate that Dunlop missed the mark on the Z2, but I'm sure it isn't nearly as bad as the Azenis. :P
PostPosted: Tue Apr 23, 2013 10:51 am
I am concerned that the Rivals may cycle out even before NT-01's. I have heard several folks talk about their half tread RS-3's and Star Specs being cycled out inside of a season! When I purchased my NT-01's, I paid extra to have them heat cycled and they seem to have about the same amount of grip now as they did when new at the beginning of last year. This really surprises me since the tires stay on the car all the time and the car is parked under a carport. Additionally, I drove on them in freezing temperatures earlier this year at Danville.
Does the compound of these high grip street tires benefit from controlled heat cycling? Is it cost effective at $15-20 per tire? Should I have my Rival's heat cycled before I take delivery?
PostPosted: Tue Apr 23, 2013 11:05 am
I have no answer for the heat cycle question Jordan, but my take would be I doubt it (i.e. having them heat cycled).
Overall regarding the Rival -- I love these things simply because they work well for "me" on "my" F-stock car. I put those in quotes since it wouldn't surprise me a bit to see that in some sizes on some cars (i.e. just think of the weight and power difference ranges for typical cars seen at autox events) that the Rival is not the tire to use. Similarly for some drivers...they may have a style of driving that is incongruent with the Rival and therefore will not be able to get them to perform to their liking. Visa-versa of course.
I've always thought tire tests done in stuff like C&D and GRM should test with three totally different types of cars (obviously nobody wants to front the costs of that). They should also take one car and test it with that group of tires totally stock and then setup to something like ST* specs.
Anyway I have no clue about how they will stack up across a wide range of cars and drivers, but they are definitely very good tires.
I need all the help I can get, so having a forgiving tire that grips super well fits me. If we got 10 runs at each autocross, it might be different, but having to create an optimal outcome in just a few runs on some course you've never driven before...well, for me, I need all the help I can get, and it doesn't get easier with age. :?
PostPosted: Tue Apr 23, 2013 11:55 am
QFT.
Plus, Seeing how well you and your car performs on 245s makes me rethink the idea that "255 or bust" is the best policy for STR.
PostPosted: Tue Apr 23, 2013 11:07 pm
Having switched from 235 Star Specs with 17K on them to 225 Rivals, there are a few distinct differences. Firstly, the turn in on the Rivals seem a bit slower. This may be more noticeable on my car because it's light and the peakiness of the Star Specs may not be as big an issue. Secondly, my very neutral car became pushy. I' m hoping that this was some manifestation of the NCCAR surface. Lastly, it's been years since I have had tires that squealed the way the BFG's did. The Michelins on my wife's mini van being the exception. Overall, I like the tires, I just have to adjust my driving to turning earlier.
Mike Miller
AutoX VP 2016/2017
Just a C Stock Miata DD
Mazda Speed 3 Family Car
Corvette Z06 Toy
