Anybody who has seen my stock NC Miata AutoX understands that there is a limit to what you can accomplish with sway bars. Look at the picture on the left. The inside wheel goes airborn because the springs are soft resulting in the stiff sway bar compressing the off side soft springs. If street classes are adopted, I might get a slightly stiffer rear sway but as you all know, my car will spin. The stiffer rear bar will just help it spin faster. So without allowing springs to be stiffer, there is a limit to how much a stiff sway bar front or rear will help performance. I replaced my stock 22mm front sway with a 25mm and feel that going bigger will not help. A few years ago, Mike Dako had a stock NC with a 32mm front sway. It did not handle as well as mine. I very much like the addition of camber plates on strut cars, though it will do me no good with unequal A arm front suspension.
JamesShort wrote:
I don't think you'd be able to find a set of staggered 17" wheels with the same widths and +-6.35mm offsets.
James, the rule that the SCCA needs to change is the quarter inch offset rule. Since almost all wheels are metric based and made abroad, they should change the offset to 6.5mm. I believe that many of us are cheating by 0.006 inches. That rule also has not changed since 1972.
