Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Novice School Instructor - March 2, 2013
PostPosted: Sat Feb 16, 2013 12:54 pm
There’s nothing wrong with studying before one arrives at Novice School. You’ll just get a little more value out your time with instructors resulting in the basics sticking a little faster.
This is a link to a basic autox video. It’s well done and makes you want to AutoX.
http://vimeo.com/12067348
Dennis Grant’s AutoX to Win: This is a structured and technical book like web site that explains how to improve yourself and your car. It starts every chapter with the basics and builds making it a good reference for beginners through experts.
http://farnorthracing.com/autocross_secrets.html
BTW, Chuck, years ago you instructed me and gave me very good advice, “Don’t try to go for top speed through the slalom, see if it’s faster by getting closer to the cones.” It wasn’t obvious, but it worked. I’ll be happy to have you ride with me for some lunch runs at the Novice School.
Mike Miller
AutoX VP 2016/2017
Just a C Stock Miata DD
Mazda Speed 3 Family Car
Corvette Z06 Toy
PostPosted: Mon Feb 18, 2013 10:15 am
I will instruct, of course! Count me in.
Club Webmaster
-2014 Mazda 6 SkyActiv DD
PostPosted: Thu Feb 21, 2013 5:39 pm
Okay guys, we're currently at 30 students and 8 instructors. Instructors will get free entry into the following Points event on Sunday, so sign up and help teach some future autocross champions!
Sign up sheet
2015-2017 President
2014 Track VP
2013 Autox VP
2002 Subaru WRX [dd]
2004 Toyota 4Runner V8
http://beastmoderacing.com
PostPosted: Thu Feb 21, 2013 5:40 pm
I've been thinking about this instructor thing.... Do we need to set a common goal on what we want to present to the students? What are our focus points for the day?
PostPosted: Fri Feb 22, 2013 11:27 pm
Only if we have a common student. :lol: Basically the focus changes depending upon how inexperienced the Novice is and how quickly they pick up on stuff. Generally, they progress at the speed that they can so the goal is not to get them to a set time, but to progress to their level of achievement.
Also to hopefully encourage them to be come regular members.
2005 Mazda 6 Wagon
PostPosted: Sat Feb 23, 2013 9:09 am
Signed up as in instructor.
PostPosted: Mon Feb 25, 2013 10:08 am
All, we need about 5-6 more instructors please. Remember, free entry to the Saturday points even and some fun runs during lunch on Saturday (and lunch :) ).
PostPosted: Mon Feb 25, 2013 11:56 am
I wish I could be there to instruct, but have a wedding to attend in KCK. Why must people get married? :stick:
PostPosted: Mon Feb 25, 2013 12:33 pm
I passed out a copy of Andy Hollis' autocross tips during the novice walk last time, and it seems well-received. If you'd like a template on which to build what you will teach novices, this could be a good starting point. I tried to upload a .rtf of the file but the forum won't let me, so I copied and pasted below. Print out for your use, or grab a copy at the Novice School:
ANDY'S TOP TEN AUTOX DRIVING TIPS--(Andy Hollis, multi-time Solo National Champion driver)
1) Position first, then speed. Positioning the car perfectly is more important than trying to attain the highest potential speed. For example, you will drop more time by correctly positioning the car nearer to slalom cones than you will by adding 1 or 2 MPH in speed. Same with sweepers (tight line). Same with 90-degree turns (use all of the track). Also, position is a prerequisite for speed. If you are not in the correct place, you will not be able go faster. Or at least not for very long!
2) Turn earlier...and less. To go faster, the arc you are running must be bigger. A bigger arc requires less steering. To make a bigger arc that is centered in the same place, the arc must start sooner (turn earlier).
3) Brake earlier...and less. Waiting until the last possible second approaching a turn and then dropping anchor at precisely the correct place so that the desired entry speed is reached exactly as you come to the turn-in point is quite difficult to execute consistently. Especially when you consider that you get no practice runs on the course, and the surface changes on every run, and you aren't likely to be in exactly the same position with the same approach speed on every run, etc. Better to start braking a little earlier to give some margin of error. And by braking less you can either add or subtract braking effort as you close in on the turn-in point. This will make you consistent and smooth.
4) Lift early instead of braking later. Continuing with the philosophy of #3, when you need to reduce speed only a moderate amount, try an early lift of the throttle instead of a later push of the brake. This is less upsetting to the car, is easier to do and thus more consistent, and allows for more precise placement entering the maneuver (remember #1 above).
5) Easier to add speed in a turn than to get rid of it. If you are under the limit, a slight push of the right foot will get you more speed with no additional side effects. On the other hand, if you are too fast and the tires have begun slipping, you can only reduce throttle and wait until the tires turn enough of that excess energy into smoke and heat. Don't use your tires as brakes!
6) Use your right foot to modulate car position in constant radius turns, not the steering wheel. In a steady state turn, once you have established the correct steering input to maintain that arc, lifting the throttle slightly will let the car tuck in closer to the inside cones. Conversely, slightly increasing the throttle will push the car out a bit farther to avoid inside cones. It is much easier to make small corrections in position with slight variations in the tires' slip angle (that's what you are doing with the throttle) than with the steering wheel.
7) Unwind the wheel, then add power. If the car is using all of the tire's tractive capacity to corner, there is none left for additional acceleration. At corner exit, as you unwind the wheel, you make some available. If you do not unwind the wheel, the tire will start to slide and the car will push out (see #6 above).
8 Attack the back. For slaloms (also applicable to most offsets), getting close to the cones is critical for quick times (see #1). To get close, we must move the car less, which means bigger arcs. Bigger arcs come from less steering and require earlier turning (see #2). Now for the fun part... When you go by a slalom cone and start turning the steering wheel back the other way, when does the car start to actually change direction? Answer: When the wheel crosses the center point (Not when you first start turning back!) How long does that take? If you are smooth, it takes .25 - .5 seconds. Now, how long is a typical person's reaction time? Answer: about .5 seconds. Finally, how long does it take to go between slalom cones? Answer: Typically on the order of 1 second. Given all of that, your brain must make the decision to begin turning the steering wheel back the other way just *before* you go by the previous cone!!
Since this is a mental issue, a good visualization technique to get used to this is to think about trying to run over the back side of each slalom cone with the inside rear tire of the car. To hit it with the rear tire (and not the front), the car must be arcing well before the cone and the arc must be shallow. Attack the back!
9) Hands follow the eyes, car follows the hands. 'Nuf said.
10) Scan ahead, don't stare. Keep the eyes moving. Looking ahead does not mean staring ahead. Your eyes must be constantly moving forward and back, and sometimes left and right. Glance forward, glance back. Your brain can only operate on the information you give it.
Bonus Tip: Don't forget the stuff in between the marked maneuvers! Too often we think of a course as series of discrete maneuvers. There is typically more to be gained or lost in the areas that are in between. Pay special attention to the places where there are no cones.
PostPosted: Mon Feb 25, 2013 12:51 pm
Should I create a public google doc and post a link on the Facebook event wall? This is good info for one to review in advance and consider.
Club Webmaster
PostPosted: Mon Feb 25, 2013 1:11 pm
I don't see how it can hurt. Thanks!
PostPosted: Mon Feb 25, 2013 1:37 pm
Ok I'll post it and email the registrants as well.
Club Webmaster
PostPosted: Mon Feb 25, 2013 2:20 pm
Cool :thumbsup:
Tell them to print it out if they want to, and a few copies will be available on-site (like 10-15 or whatever I have left over from Event #1)
Also, anyone with the Bright Orange Badge lanyards, please return them (if you haven't already) as I can't afford to buy new ones for every event. If you returned them already, thanks!
PostPosted: Mon Feb 25, 2013 2:42 pm
Cool :thumbsup:
Steven,
You were gone by the time I was finishing up at Danville and I was not sure where to return my BOB so I dopped it in the bin with marking objects in the trailer. Is there a dedicated bin for these in the trailer, or will you collect and store them?
PostPosted: Mon Feb 25, 2013 4:06 pm
Online
I was in, and then I was out. Now I'm back in. But I have to roll out of Danville by 2:00pm. I've got a family event at my parents that I have to go to.
