Chuck Branscomb wrote:
...and as a follow on. Requesting any and everyone's thoughts on this:
I need Rivals in two sizes for the M3: 245/40-18 front and 275/35-18 rear. The rears will not be available until June. I have a set of wheels I want buy from Tirerack that are on closeout, so I need to get them soon before they're gone (stock widths which are 8.5" front, 9.5" rear). The 245/40 Rival is available now.
So, I'm pondering the crazy idea of buying the wheels with 245/40s all around and running with the 245s on the rear for events in the next few months, both THSCC and others perhaps. Come June, I'd get the 275s for the rear, and then end up with an extra set of fronts to put on as I destroy the other fronts (although these things apparently wear really well -- suppose Michelin (BFG) has used their compounding technology they developed with the Pilot Super Sport, in some way, to get the great performance to wear ratio with the Rival too).
I'm worried going this route that the M3 will be a ***** to drive with only 245s on the rear, trying to put power down (414hp) through them. It would only be for a few events, so perhaps it's a benefit to help me adapt to the new car anyway (since it's powerband is soooo different than my M5).
See, I can justify any car related purchase. Give me a minute and I'll figure out more wild justifications. Wait. There is one more. Jackie (living down in Greenville, SC) is going to 8.5" wheels with 44mm offset all around for her E46 in STX, and wants to run the Rival in 245/40 size, but isn't sure they will fit without rubbing since the car has been lowered with GC coilovers. The front wheels I'm ordering have a 44mm offset, the same as her wheels (I have to use a 15 or 18mm spacer to use them on the M3). Hence I can let her try one of these fronts to test fit the 245 Rival.
Thoughts? Would you go for the 245 rears for a few months in this position?
Well my E46 is pushy as a beast in stock form, not sure if the M3 would be the same way, but with all those ponies, you should get a lot of on throttle rotation on demand so it is probably a bad comparison. If you went with 245s all around I'd just want a big ole' front bar on that thing
Re: Jackie's Car. So I have 265/35/18s on a 18x9.6 et45 in the rear of my E46 on stock springs and it only rubs on hard bumps and it just rubs the inside rear of the liner (not the junction of the fender and bumper like some combos with lower offsets. After I do the RTABs, I'm going to dial in more negative camber in the rear to combat this (and the front). That being said, I highly doubt 245s on a 8.5" wheels with 44mm offset will be a problem. Seems like they should be fine, even if it is lowered (doesn't look very lowered to me, what 1/2"?)
