When trying to use PAX/RTI values to evaluate your performance, there are several things to keep in mind as to how those values relate to our local events. The PAX is generally assumed to be an evaluation of cars prepped to the limit of the rules, driven by the best drivers in the region/country, and on grippy concrete surfaces.
At local events, those three assumptions generally do not hold up well. With the exception of a very few, most local competitors are not the best drivers in the country, the cars aren't prepped to the limit of the rules, and only Laurinburg could begin to qualify as a grippy, concrete surface.
So, while it is easy to assume that PAX is an equalizing value for comparison, realize that it is an imperfect system. If we took the best drivers in the country and put them in our cars, on a gritty surface like Sanford, you would likely generate different indexes for each class than those currently published.
This is all speculation, but I would bet that:
- the spread between stock and mod cars would be much less
(in other words, a mod car would not be as much quicker than a stock car on a gritty surface)
- high horsepower rear wheel drive cars (like Mustangs, Camaros, Corvettes) lose some of their strengths on grittier surfaces
- AWD cars usually do quite well on on the grittier surfaces
- cars on slicks would not have as much of an advantage, if any, on grittier surfaces. Some folks speculate the best tire for Sanford is a full tread race tire like a Kumho Victoracer, or full tread street tire, like a Falken Azenis.
In fact, I believe there are times that slicks are not as fast as tires with tread- and the super gritty surface is an example. (Think of it like driving in the rain- the grit has to have somewhere to go).
- the mod cars need the grippy surface in order to take full advantage of the advantage offered by the modified suspensions
And finally, some cars are reportedly just easier to drive at 10/10ths than others. I'll let you figure out which those are.
Though imperfect, the PAX is the best we're willing to do, and we live with it for the purposes we use it for. Some people would say the above are just excuses for those that don't do well in the pax. Others would say that they are valid arguments.
There are also those drivers that are just so good, that they will prove the above wrong because they could drive anything to the limit under any conditions and make us all feel really slow. I don't know that they really disprove the above, they just make us mere mortals, go WoW- how'd he do that?
We've got a few guys in this club that seem to defy the laws of physics....
(Whitney, Whipple, GH, Rasmussen, etc....)
Just food for thought.. not trying to start another 10 page discussion on the validity of pax, but I wanted to give some of the other considerations to keep in mind when trying to use PAX to evaluate your performance.
One way that I try to track my progress using the pax is to evaluate my pax time against the winning pax time. I'll divide the winning pax time by my pax time and give myself a grade. Hopefully, as the year goes on, I'll see that grade improve.
Perhaps the best way to evaluate your performance, and take the car out of the equation, is to have a co-driver.
Miles
