Here's a link to my fastest run. Interesting to note that depsite 130* asphalt temps (air temp 92), my fifth run was my fastest and the tires were not nearly as hot as I thought they should be, given that I had only 15 minutes to cool them (no sprayer) from the prior run. On review, it's obvious where I lost time....
1) coasting into the 3-cone wiggle
2) coasting again into the uphill left-hander.
3) Not downshifting at the uphill left-hander
4) too early on throttle on the final uphill right-hander causing me to push wide.
Probably could've been faster through the first right-hand sweeper also. I think those four areas at the end of the course could have netted me almost 1 second. Sigh....much more to learn!
http://youtu.be/qt-SVbebX_4I thought going to 1st in the uphill left hander was going to be faster after day 1, but I also coasted into that turn all 5 runs on day 1 and was at about mid 3000 rpms coming out in 2nd.
On day 2 I knew there was a lot of time to be made up attacking that turn more and in doing so, I came blasting out of the turn at near 5k rpms.
Anyway, in an AP2, I'm not so sure the 2->1 was necessary. In an AP1, maybe, though Zach hit his fastest time staying in 2nd.
