Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Autocross Instant Results for smartphones
PostPosted: Mon Feb 20, 2012 9:21 pm
I couldn't connect from down where I was handing out time slips. If I could have, that would have rocked. That is, if it had been updated so that I could have read the times for each driver as he came through. Not an issue however, and I'm grateful for the work that went into producing the app. Thanks.
Gwen
PostPosted: Mon Feb 20, 2012 9:49 pm
Carlton Whitehead wrote:
Range:
The range of the wireless network is pretty limited if the trailer is located between you and the router (inside the bus). On the other hand, my phone could see but not quite join the THSCC network from near the covered area way at the other end of the site. I also heard reports of successfully using it from the pit area.
What is the make and model of the wireless router?
PostPosted: Mon Feb 20, 2012 9:50 pm
Range:
It's a DD-WRT flashed WRT54G if I remember correctly.
PostPosted: Mon Feb 20, 2012 10:00 pm
Range:
The reason I was asking was that I was thinking of an external antenna that could be set on top of the bus and likely greatly extend the range. I assume the router will take a typical ext antenna. I think there are some inexpensive magnetic mount antennas available.
PostPosted: Sat Mar 31, 2012 9:05 am
I've enabled the bug tracker on the launchpad project and entered all the software-related bugs I could remember. I'm going to code some fixes this weekend. If you had any trouble with the software (not counting infrastructure issues like wireless range), please check out the bug tracker and submit a report if the issue isn't listed yet.
https://bugs.launchpad.net/axir/+bugs
03 Nissan Altima
02 Honda S2000
PostPosted: Tue Apr 24, 2012 8:37 am
Following Points #2, it's apparent to me that there is still some work left to do with the Autocross Instant Results (AxIr) software.
I believe it was Noah who donated the new Timing & Scoring laptop that we used for the first time at Points #2. Thanks Noah, it's a huge improvement over the old one! I spent the morning moving the AxIr software from the old laptop over to the new one, and got it up and running just in time for Mary to start setting up the AXware file for the EV challenge autocross.
There was an issue with AXware on Windows 7 that prevented our points event from being able to save properly. I think we can chalk that up to a Windows XP -> Windows 7 migration issue. Since AXware wasn't able to save its file for most of the first heat of our points event, that's why it wasn't showing up in AxIr.
There was another issue where the Raw and PAX times would show 0.000 as the fastest run (who brought their teleporter???) for any driver with a DNF. This is definitely on my bug list to fix.
Another issue came up with the classing/category results where tircs, tirbs, tirhs, etc, were being treated as separate classes instead of all falling under TIR category. This was due to the classes being entered into AXware in lower case. All of the sample files that I collected from the old laptop had them all in upper case (TIRHS, etc), and I never thought to handle that. Also on my bug list to fix.
The current version of the AxIr also has a major achilles heel in requiring the AXware operator to manually save the file frequently. I noticed that AXware is constantly updating another file, but it's structured a little differently, and there might be some file locking issues that come into play if I change AxIr to read it instead of the one it's using now. I'm going to look into reading that file, and I will be testing thoroughly with a copy of AXware. However, I don't have any samples of those files from our past events to test with. If someone can either give me the laptop for a day or upload the *.st1_log files to me, that would really really help.
03 Nissan Altima
02 Honda S2000
Last edited by Carlton Whitehead on Tue Apr 24, 2012 9:27 am, edited 2 times in total.
PostPosted: Tue Apr 24, 2012 9:11 am
Any benefit to running AXWare on WIN7 via compatibility mode for XPSP2?
PostPosted: Tue Apr 24, 2012 11:16 am
I think it's just a permissions issue. We probably should move the AXware's event data out of Program Files to somewhere more appropriate. It should probably go in a folder directly under the C drive, so AxIr (Apache running as the apacheservice user with limited permissions) can see it without too much permissions hassles.
03 Nissan Altima
02 Honda S2000
PostPosted: Tue Apr 24, 2012 1:10 pm
I have both of the computers (new and old) and I would be glad to meet you tonight or tomorrow.
Professional Student
2006 MINI Cooper S JCW
PostPosted: Tue Apr 24, 2012 4:01 pm
Depending on how the computer is set up, you'll probably wind up with issues trying to write to the root of the C:. A folder under the root should work, but putting the data in C:\Users\$User\Documents should work as well.
PostPosted: Tue Apr 24, 2012 4:26 pm
I was thinking something like C:\AXwareData\ would be a good place to point it. I'd really like to avoid granting the apache service account any access into the user's profile, let alone the Documents folder.
03 Nissan Altima
02 Honda S2000
PostPosted: Tue Apr 24, 2012 5:22 pm
We should have a brainstorming session with you, Noah, and I about best ways to set all this stuff up. I think between us we can come up with some great ways to improve the THSCC IT systems!
2015-2017 President
2014 Track VP
2013 Autox VP
2002 Subaru WRX [dd]
2004 Toyota 4Runner V8
http://beastmoderacing.com
PostPosted: Tue Apr 24, 2012 9:48 pm
Yes!
Club Webmaster
-2014 Mazda 6 SkyActiv DD
PostPosted: Tue Apr 24, 2012 9:52 pm
All I have to say is Carlton, Noah and Zach are awesome from a IT support and general event support standpoint. Thanks guys.
PostPosted: Sat Apr 28, 2012 12:50 am
Happy to help out!
I just finished coding some fixes for the issues that came up at the last event. It turns out there are some differences in the way the new version of AXware writes its statefiles that caused both the issues that came up (DNFs had 0.000s times, categories weren't found in class names "tircs", etc). Pass out time now.
I should probably take another look at my fixes in the morning after I've had some coffee.
03 Nissan Altima
02 Honda S2000
