Post new topic Reply to topic  [ 402 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 27  Next
 Post subject: Re: STR in 2012
PostPosted: Sat Dec 03, 2011 1:15 pm
Why not 17x9?
PostPosted: Sat Dec 03, 2011 2:03 pm
Official Mustang Tire Corder
Stephen Westerfield wrote:
If anyone sees a Saner bar for sale let me know. Trying to figure out what I'm going to go with. Damn if the Grendon bar isn't expensive. I can't believe Addco doesn't make anything for it.
Didn't Buckley once say they would make a bar for anything if you called them. They are somewhere in the Hickory area IIRC.
Probably worth a call at least. Couldn't hurt. Is anyone else interested? Group buy?
Stephen Westerfield
Last edited by Stephen Westerfield on Tue Dec 06, 2011 5:17 pm, edited 2 times in total.
PostPosted: Sat Dec 03, 2011 2:36 pm
JamesShort wrote:
Why not 17x9?
Because they cost more, and I didn't really see a benefit to it for my needs.
PostPosted: Sat Dec 03, 2011 4:09 pm
Or group buy the Gendron bar? I would be interested in that....provided I procure a car upon which to mount it. :roll:
PostPosted: Sat Dec 03, 2011 6:45 pm
The base price for the Gendron bar is $625. Wow.
PostPosted: Sun Dec 04, 2011 12:46 am
JamesShort wrote:
Ap2 bumper is legal by 14.2.F.1
From what i remenber hearing, there is some shaving to make it fit which is why the mod is illegal. I will let the s2k guts speak of what is involved OR i will look it up monday night if im still curious enough.
PostPosted: Mon Dec 05, 2011 7:48 pm
So are the stock endlinks ok, or should I upgrade those when I replace the front bar?
PostPosted: Mon Dec 05, 2011 7:58 pm
I used the stock end links with the eibach bar. They are pretty stoudt. I would think the bar manufacturer would supply them if necessary.
PostPosted: Tue Dec 06, 2011 5:17 pm
Addco said they would make me one. Is anyone else interested? Are the bars the same between AP1 and AP2?
Stephen Westerfield
PostPosted: Tue Dec 06, 2011 5:47 pm
Thickness? Hollow vs solid? Adjustability? Price? Estimated spring rates?
...could be interested if it fits my plans. Thanks for making the call!
PostPosted: Tue Dec 06, 2011 6:04 pm
I was going to have them make me a 32mm hollow adjustable bar. No idea on price, but he said they normally run in the $150-175 range, so I would think $175 max.
Stephen Westerfield
PostPosted: Tue Dec 06, 2011 7:12 pm
Why not just get the Eibach? Same specs, same price.
PostPosted: Tue Dec 06, 2011 8:43 pm
depends on the thickness of the bar's wall, as well as the length of the lever arms (relative to a perpendicular dropped from the longitudinal axis of the main bar crosspiece)....
Pi x G x (OD^4-ID^4)
16 x B^2 X L
B= length of lever arm
G= modulus of elasticity (usually a constant since all bars are made of similar steel)
D= diameter
L= length of bar
Stephen, how many adjustment holes will they make?
PostPosted: Tue Dec 06, 2011 8:48 pm
Frequently moment arms are not 100% perpendicular to the torsional sectional and therefore there is a bending moment element to that equation as well.
PostPosted: Tue Dec 06, 2011 9:17 pm
:roll: OK, fine. *&)@&# engineers.... :wink:
The point is that not all hollow bars are made equal, and the difference between ID and OD (and length of lever arm) is critical. The 32mm Eibach bars are reportedly not that much better than OE, about 360-420 lb/in, at least how they were measured recently on S2ki.com (caveat emptor). OE varied by MY, but ranges from 300lb/in (02-07) to 393 lb/in (00-01, and CR) with 08-09 in the middle at 353. In comparison, the Gendron 32mm hollow (wall thickness 6.25mm) bar has rates from about 460 to about 900.
Not all 32mm bars are the same....
