Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Anyone going to VMP 1/23 for the Nasa autox?
PostPosted: Fri Jan 07, 2011 7:56 pm
It is a big course and they do 5-6 runs. $35. Should be fun.
PostPosted: Fri Jan 07, 2011 8:23 pm
Oh god completely different classing rules.
1) Engine swap: All engine swaps must be evaluated for new base classification by
the NASA-X National Director on an individual basis, unless a base class for
the particular swap is listed above in 1.2 Base Classifications or in Appendix A.
Please refer to section 1.5.
Ugh.
PostPosted: Fri Jan 07, 2011 8:25 pm
Yep, you'd probably be your base class plus one.
PostPosted: Fri Jan 07, 2011 8:36 pm
Believe it or not, if I run on street tires I can stay in my base class and I believe I only have 11 points total. And I could show up with my interior basically gutted.
205 tires -7
MS3 +3
Intake +1
Headers +2
Catback +2
Shocks +3
Springs +2
Sways +2
Bushings +3 (I think)
PostPosted: Fri Jan 07, 2011 8:49 pm
Bushings are free I think.
I start at C* and because of turbo I get another 5 pts so I start with 12 points :(. But my skinny tires bring me back to 7 and the fsb and dampers keep me in C.
PostPosted: Fri Jan 07, 2011 9:07 pm
Ugh.
For you, I'd just do points like you did a head/cam swap.
Edit: nevermind headswap is the same and the vvt engine into an NA is not on the approved list. I don't quite understand their update backdate though.
PostPosted: Fri Jan 07, 2011 11:25 pm
Hmmm... maybe. The STi is back, just need to drive it 1000 miles tomorrow and change the oil.
PostPosted: Tue Jan 11, 2011 11:49 am
I emailed Jon and he said the course will easily be 60+ sec and 5-6 runs. And like zMax, VMP has rules with local HOAs about start time on Sunday, which is noon, so you don't have to get up too early to make the 1:45 drive to Petersburg. And with a cap of 60 drivers, we should be done at a reasonable time.
PostPosted: Tue Jan 11, 2011 3:13 pm
VMP is huge, and in pretty good shape, unless it's changed since the last time I was there. Only annoying thing besides the drive is the ripples in the pavement in some places. Stockish Subarus won't care, though.
PostPosted: Tue Jan 11, 2011 3:16 pm
Yes I did the EVO school there. Great lot. I didn't notice any ripples (though the course could have been designed around them and I didn't see it). Since it is a drag strip and they do oil changes in the lot, there are a few places where there were spills but the course designer avoided those spots (nothing that kitty litter couldn't dry up).
PostPosted: Tue Jan 11, 2011 3:28 pm
Yeah, if you get a nice run on pavement directly across from the grandstands, it gets seriously bumpy. If it's slow, it's fine. I was there one time where I was pretty deep into the Celica's 3rd gear (around 70mph or so) and it got a little hairy.
That said, other than when it's brutally cold, the grip is pretty good there. - AB
PostPosted: Wed Jan 12, 2011 2:40 pm
Okay, because I'm stupid -- where would double-adjustable shocks generally fall on the Suspension/Brakes/Chassis page? I couldn't say whether the resevoir on mine is fixed or has a connecting hose without going out to the garage, and it's COLD out there! :shock:
PostPosted: Wed Jan 12, 2011 3:06 pm
What shocks are they? And will the extra 3 points by taking the first level bump you a class?
PostPosted: Wed Jan 12, 2011 3:16 pm
Nope, you're right, I mis-read and I've either got #1 or #2, so I'm still up a class (just barely). Thanks!
PostPosted: Wed Jan 12, 2011 3:23 pm
What size tires? And rcomp or street?
You start with a base class of C with an initial 14 points
+14
+7 or +10 for shocks
+2 for FSB
+ or _ (depending on how far from 255mm you are)
+ 0 for street tire or +10 for R6/v710/BFG R1 or +13 for A6
Unless you are really skinny street tires (ie with a large deduction) it seems you are pretty deep into the 20 point range, so you'd run as NXB.
