William Gravely wrote:
I still don't consider it a screaming deal at $33k (already had to replace the alternator at $400 and a window regulator at $500).
Well, you could have bought a new SUV for $33k that would be worth $20k now 14 months later. Instead, you could flip that car now and probably make $5k.
Destroys rear tires. My PS2s are toast at 1 year and 14k miles with about 4-5 events, a lot of those being 2-driver (thanks Jackie) This is probably due a bit to my overzealous driving.
I'm thinking back to Donnie describing the issues with his Cayman autocrossing and it wearing the inside rear on its outside edge from too much positive camber under heavy cornering loads -- was that correct Donnie? I know nothing about 911 tire wear under autox torture, but I'm curious if it is that or actually outside, loaded, edge wear (or both?).
I wonder how it will respond to just a large FSB (compared to my experience with strut cars, etc.). It's one thing to slap one on an E46 stock class car and gain grip due to reducing the nasty camber under load and also help hold down that inside rear tire with no LSD, but on a 911, I'm curious if it will make the corner exit that much harder to get power down without plowing a field?
Anyone have any idea what prep someone like Gary Thomason did to the SS-class winning GT3? (i.e. larger FSB?) I would assume to *some* extent following a similar prep to the 996 40th would at least get you in the ballpark?
