While Brice's recommendation makes perfect sense in his case (driving a ST prepped car, which would get him essentially an SP PAX in TIR class), it would not be my recommendation for anyone driving a non-ST (i.e. Stock, SP, etc.) class prepped car.
I'm not so sure about that. I think an ST* car has an advantage PAX-wise in the TIR category compared to the *S and *SP cars, also in TIR. To use 2009 numbers:
DS: .819
ST: .818
So factored into the DS .819 is the fact that you can be running on r comps, so if you enter in DS-TIR then you are still getting the .819 PAX modifier but you are not maxed out for the class that that PAX number correlates to. So when putting a DS car in a TIR category and keeping the same PAX, compared to other *S and *SP cars, then this differential for the tires is probably the same so it's pretty fair. Apples to apples.
However, if you have ST* cars in the mix, their default open PAX already assumes they are on street tires. So compared to the *S and *SP cars if you are comparing a ST-TIR and DS-TIR, the ST car should have a higher PAX, or more intuitively, the DS car should have a lower PAX to basically remove the r comp portion of the PAX. Again, if there is no ST* in the TIR category (which I found on the THSCC website should be the case), then it does matter since all *S and *SP PAX equally assume that you COULD be on r comps, but in the case of running TIR, you are not.
Anyway, are you running with r compounds in DS? How are you liking the 135? I drove one about 3 months ago and it had the flattest powerband of any turbo car I've driven....no lag at all! Granted the turbos are about the size of a fist so that's to be expected
