 Post subject: Network LAN/Cable Tester - Recommendations
PostPosted: Tue Feb 28, 2006 11:47 pm
I'm looking to buy an inexpensive network tester to test wires with rj45 and rj12 connectors. Anybody have any recommendations on what brands/models to choose and/or places to buy online or local?
I basically need to test continuity of wires.
Thanks
Jeff
GS - 17 Honda Civic Si
STS - 91 Honda Civic Si
S04 - 00 Subaru Impreza 2.5 RS
http://www.kestrelracing.com
 Post subject: Re: Network LAN/Cable Tester - Recommendations
PostPosted: Wed Mar 01, 2006 11:30 am
SUPER Post Whore
Thanks
Jeff
IMHO, a good multimeter can check this with a Resistance test/diode test(if you already have one), or you could just use a doubleA battery and a cheap LED that can drive it to check small voltages across the wire.
That, or you could buy a whammo-dyne RJ45/RJ11 connect-o thingy that costs $texas, but tells you all the correct pinouts. I have heard tales of such devices, but I have only used the two above.
Edit: I have just multimeters I have gotten from Sears/Lowes, and battery/diodes at Radio Shack.
- dow
PostPosted: Wed Mar 01, 2006 10:27 pm
Cyberguys has a resonably cheap tester to find faults in RJ-45 connections.
http://www.cyberguys.com/templates/searchdetail.asp?T1=115+3172&dept=lch33&search=1to25-1&child=1to25-1
PostPosted: Thu Mar 02, 2006 7:39 am
Thanks, I'll check them out.
Jeff
