DickRasmussen wrote:
Mike - Outstanding job. Great to have the tools (welder), skills, and persistence to pull this off!
I'm disappointed that a modern engine with relatively speaking "lots of space around the engine" would break manifold studs like old engines frequently did/do in RV's and vans. Any idea how to prevent the problem and which engines, if any, do NOT have the problem from the factory?
Thanks,
Dick
It's more of a duty cycle thing ... these engines are prone to warping exhaust manifolds when subjected to heavy towing loads (I have been dragging a 26' camper around with a lead foot). Once a leak develops, it tends to cook the manifold around the leak and starts a corrosion cycle on the bolts near the leak. Only the bolts at the leaking port were broken and corroded, everything else came out fine. I think if I had pulled it when the leak first developed I would have had a much better chance of it coming out without snapping.
One other guy I talked to mentioned that these engines run too lean (for fuel economy) which further exacerbates the hot manifold problem.
Considering I've got 86k out of the truck and a lot of that was heavy towing, I'm not at all disappointed. I've pulled 6-7k enclosed and camper trailers through mountains without much fuss.
