 Post subject: MINI BUS DAY - This Monday 07/03 - HELP NEEDED!
PostPosted: Sun Jul 02, 2006 12:19 am
Hi Y'all -
The last few planned bus days never happened, and the bus is going to be making a long trip on Thursday to the SCCA RallyX Nationals, so it's time to DO A LITTLE CLEANUP!
What: Bus cleanup and maintenance day
When: Monday July 3, 10AM-2PM?
Where: Kevin's place in Four Oaks
Who: NEED VOLUNTEERS! The more the merrier. I have a long list of things to do, but let's at least get it clean and nice looking to represent the club well at the SCCA event.
PLEASE PLEASE post here if you know you can make it out for a few hours, even to do a few simple things like sweeping, vacuuming, window cleaning, tire pressures, etc.
I'll post a list tomorrow of all the stuff to be done.
Please step up to help iout your club if you can! Thanks!
PostPosted: Sun Jul 02, 2006 5:54 am
I will be there at 10 AM
B2
2004 C5(415whp,390ft/lbs),
1997C5,1997Trans Am, 1986 C4,
PostPosted: Sun Jul 02, 2006 7:58 am
SUPER Post Whore
I will prb be there as well. That is as long as the rear end doesn't fall off the Red car... more news later.
Pencil me in.
- dow
PostPosted: Sun Jul 02, 2006 11:27 am
Pencil me in.
- dow
Damn those spectators for breaking the rear of your car- that girl must have weighed at least 50 lbs!!! :)
Seriously, what's wrong with the car?
Sorry I can't be there to help with the bus, I'm actually *working* on Monday...... :shock:
Bret
PostPosted: Sun Jul 02, 2006 4:43 pm
Bernie - Great, see ya there. Brian - hope you can make it.
NEED A FEW MORE PEOPLE!
Reminder -- volunteering for this should make you eligible to run in the Greenville Invitational Night Event this month!
PostPosted: Sun Jul 02, 2006 4:56 pm
street tires suck
If it wasn't in the middle of a work day I would be there.
adamb
Adam Breakey
PostPosted: Sun Jul 02, 2006 5:21 pm
I'll be there. Can you bring your R134 air conditioning gages or adapters as my gages don't fit R-134. The air conditioning appears to be working but might as well check it. Could you also bring the charging chart that you had.
Mitch Moore
PostPosted: Sun Jul 02, 2006 7:13 pm
Yeah, the AC periodically goes weak while driving. PLEASE check it! :lol:
See you guys at 10AM or whenever you show up. If you have any questions or requests, give me a call.
919 963 6951
PostPosted: Sun Jul 02, 2006 8:12 pm
Good idea, will do.
PostPosted: Sun Jul 02, 2006 8:30 pm
Here's the (reorganized) list. If you're planning to come, please print it out, and bring some stuff to clean with so we all don't hog all of Kevin's stuff. Thanks!
MONDAY WORK - MAIN LIST
Bus floor sweep / vacuum / mop
Bus interior wipedown / clean
Bus window cleaning + rain-x windshield?
Bus interior organization / labeling / go through all drawers
Bus + trailer exterior wash
Trailer interior vacuum, mop, wipedown
Trailer interior organization / labeling / go through all boxes
Washer fluid
Mechanical inspection
Tire pressures
Review everything for state inspection
Really annoying rattle in overhead bin. (PA board I think)
- WHITNEY
Repair / fix loose door handles and hinges
- WHITNEY
check condition of roof speakers and panel / tighten screws
- WHITNEY
MONDAY WORK - OPTIONAL LIST
Needs "owners"
Check AC pressures
- MITCH MOORE
Bus exterior cleanse? wax? (What products might help the gelcoat?)
Oil + filter change - Need oil and filter
Fuel filter change - Need filter
New brake controller install
Exhaust repair? Is it done?
Hitch system lube
Lube chassis
LATER THIS WEEK - PRIORITY
NC Inspection
LATER THIS WEEK - OPTIONAL
FUTURE BUS DAY
Bus high idle? - Need research
Broken passenger side convex mirror replaced - Need part
Relocate "Wait to start" light to a more highly visible location.
Low-voltage flashing warning light - Need part and plan
Low-voltage procedure labels next to warning light
PA wiring cleanup
- HARVEY?
PA wireless mic antenna problems?
- HARVEY?
FM modulator station reset?
- HARVEY?
Louder radio and speakers? - Need parts
Install 12v fans on walls
Hard-wire power to ammeter (req 12->9v conversion) - Need voltage regulator
External wireless antenna mount
- WHITNEY
Need to find some 50 Ohm cables, need connectors
- BAAKE
External timer plugs - Need parts and plan
PA alternator whine? - Still happening?
FRS to PA instructon label? Location?
- HARVEY?
Evaluate solar as an option -- for onboard batteries + external ones
Make brooms easier to get out?
PostPosted: Mon Jul 03, 2006 6:34 am
adamb
Ditto
PostPosted: Tue Jul 04, 2006 9:52 am
Hey, guess what... after you guys left, I went over to close the hood on the bus and heard hissing. Checked it a couple hours later, still hissing. Hope it's still hissing after next weekend, or it's going to be a loooong trip to VA and back. :lol:
PostPosted: Wed Jul 05, 2006 12:59 am
DONE
Oil + tranny fluid level check
Check AC pressures
Make brooms easier to get out (added spacer)
TO DO THIS WEEK (for Kevin)
NC Inspection
Tire pressures
Washer fluid
Check condition of roof speakers and panel / tighten screws
FUTURE BUS DAY
Hitch system lube
Lube chassis
New brake controller install (relocate to better position)
FUTURE BUS DAY - Optional / needs owners to step up
PA wiring cleanup
- HARVEY?
- HARVEY?
- HARVEY?
- WHITNEY
- WHITNEY
- BAAKE
- HARVEY?
PostPosted: Wed Jul 05, 2006 7:25 am
NC Inspection
Tire pressures
Washer fluid
Identify/fix hissing sound
Added a new item for your list there, Mike. Just a guess, but I'm thinking that sound was the AC leaking. If it's a dust bowl up in VA, and it will be if it's dry, we cannot open the windows on the bus or everything inside will be coated.
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Wed Jul 05, 2006 8:03 am
NC Inspection
Tire pressures
Washer fluid
Mitch is going up to Kevin's this morning to see if he cna figure it out. The AC had some charge in it when we started working -- the leak actually must have developed/worsened while we were charging it. Hopefully Mitch can figure it out!
