Carl Fisher wrote:
Hey Brian, thanks for the offer! I'll contact you offline later to make arrangements.
Rob, the "old" laptop needs 128M of RAM so we can install Win2k, which is needed to run AXware. I can do the Win2k and AXware installations, but I need to source the mem chips. Also, both laptops have stopped working off of battery power for some reason (as in you unplug external power and the machine goes dark instantly). Yet at least the battery on the old laptop (don't have the other one here) shows it's got a good charge, so it appears the laptop doesn't "see" the battery. That's the service part.
The memory is easy to install, there is usually a little door on the bottom that you just unscrew. Then you just slide/snap it in. Just have to make sure you have the right kind.
As far as the battery, where is it showing good charge? On the task manager in the lower right? Or, are you checking it on the battery module itself? The taskbar charge indicators are quite un-reliable. I would bet it just needs a new battery.
