 Post subject: Bus - Final update for a while!
PostPosted: Wed Jan 26, 2005 9:30 am
Thanks for the offers for help today. Mitch Moore was here almost all day working on the bus AC and he was able to give me a hand with the new hatch install. There were a few gotchas during the install, but I managed to get it in (took 3x longer than I thought it would though). The interior PA noise level should be MUCH better now than it was with the temporary plywood hole cover.
Also in the good news department - we found one (minor) AC leak and fixed it (man it's nice to have good AC tools - Mitch has a leak detector!). Mitch pumped the system down and refilled with (godawful expensive) R134a. AC is up and running in the bus! We're still not 100% sure that there isn't some other minor leak, but we'll check the system pressures at the next couple of events and see if it's dropping.
Bowie and Vincent came to pick up the bus and take it to Greenville. The major work is done for a while! There are some minor "continuous improvement" things to take care of mostly at the events, and probably one more bus day this summer, but for now I'm going to say the bus is DONE!
Thanks to everyone for all their hard work!
Meantime, y'all can ponder the list of future to-dos:
To do / Future bus day
Helmets (arriving Wed) - toss old, label and put up new - MW
PA - Easy disconnect power plug, figure out best amp option
Remove unused AC condenser, clean out radiator - ?
Install new steering rag joint - Dustin F?
Get weighted plate - MW
Install fender flares - ?
Brake light still not coming on when P brake set? - ?
Sponsorship - contact me for details
Loose battery charging - 5w solar panel?
Side door fold-out step - plan - Joe Dobner?
Source 3" hose for remote running - Mike D?
Window props - Jason M?
Bus chair box?
12v T&S fans install - Ryan H
Sell the wheelchair lift - Ron S?
Posted SUN 04/17:
Been a while since I posted an update. The big news is that we pulled the trigger on the dual wheels, which we should have done a long time ago. Stability problems are GONE
Overall we're in good shape. Dustin and I spent some time today building a new corner-stroage unit for the brooms, canopy, shovels, and other tall stuff. It should do a better job than the temporary box we had in there at keeping stuff from flopping around and tearing up the walls.
The bus is leaving Tuesday for G'ville (thanks to Vincent and Bowie) and will travel next weekend from there to Clayton (NEED TO FIND SOMEONE WHO CAN DRIVE IT THERE ON SAT!). After that I expect to leave it there in Clayton (if Bret will have us) or maybe Four Oaks for a while. SO, I'm trying to get all the major stuff and loose ends wrapped up so it can be out of my hair for a while :)
Also, FYI the bus will be used at the Rockingham HPDE and TT in June for infrastructure (mainly PA) support. Rob Harvey is working hard at perfecting the PA system and adding some improvements (weatherproof remote PA speakers and an FRS radio tie-in for remote organizer announcements) for this event.
I'm also going to post another "special projects" thread about some other longer-term projects that need to be handled. Between the BMW farm Rally-X and the June TT I expect to organize one bus day (probably May 7/8 or 14/15) to take on some of these things.
Last edited by MikeWhitney on Tue Apr 19, 2005 11:31 pm, edited 28 times in total.
PostPosted: Wed Jan 26, 2005 9:36 am
Here is the growing list of work completed:
DONE 4/18-4/19
Install new hatch and rewired speakers
AC Repair - Mitch Moore
- Troubleshoot bad relay, complex switching system - OK
- Fixed leaking fitting
- Pulled vacuum, charge w/ R134a, tested good
Built and installed new corner storage unit, reorganized stuff
PA improvements - Rob H
- Tested FRS radio PA input - works!
- Tried out different amp, reattached to panel
Remount brake controller
Spare keys - stored in trailer
Install new latch for side emergency window - MW
Dual rear wheels - new lug nuts
Ordered new helmets
Caulk leaking screws + gap in trailer
Add loom + zip ties to any exposed underside wiring
DONE Mar-Apr
Re-secured rear door handle
Re-secured loose 12v lighter outlet
Installed new 105 AH deep cycle battery in box
Moved loose old Optima to trailer (now 2 in there)
PA system
- replaced big black pa (output level problems)
- purchased $30 ratshack mixer (works awesome)
- used big 100A car audio amp
Hatch ordered
Trailer tongue weight measured = 550 lb
Hinges second coat
Dual rear wheels - test fit & test drive
DONE 3/10
Crash repair
- Front seam strips replaced, caulked with butyl rubber, and capped with plastic trim
- Rear seam likewise repaired
- AC mount repaired
- Temporary plywood hole cover installed
- New PA speakers installed and rewired
New "quiet" front table holders installed - Toggle clamps kick ass
Both deep-cycle batteries tested bad and were sent to the battery graveyard
Replaced accessory battery with one of the 13-year-old Optimas that came with the bus and tested fine
Retightened hitch ball (crappy impact gun!) - it was probably the source of some clicking/popping that was happening
Retightened hitch bolts - ditto
Added shim to the receiver tube - lots of play
3/08/04
Mechanical work done by Randy Melton
- Replace brake master cylinder
- Replace front calipers - slight pull under braking - they're cheap
- Turn front rotors
- Bus rear brakes bleed, adjust, check shoes
- Bus dash brake light - troubleshoot
- Differential fluid change
- Transmission flush
- Coolant flush
- Left front upright balljoint replaced
DONE 2/24-28
Wire remote mike jack (near tables) - Rob Harvey
Trailer spare tire in trailer - Mark C / Scott J
Replaced batt tray, wiring panel locks (same key now)
Added some THSCC logos
Nut & bolt table hardware
Added some labels to electricals
Put loom over inside exposed wiring
Made swing table hold-down
Organize bottom drawer
Mount spare trailer ball / organize towing accessory box
Add rubber feet to display box lid - MW
Spare batteries mounted on trailer shelves
PA accessory box mounted up
DONE 2/23
Add padlock hinge to rear door
Lube slider windows
Wash diesel soot off of trailer front
Add solar trickle charger to bus batteries
Display loose bracket/screw
Convert display power cables to banana plugs
Make banana plug receptacle -> battery clip adapters (for display)
Make lighter plug recptacle -> banana plug adapters (for timer box and others)
Install Ammeter to acc battery
Troubleshoot wireless PA hum - Rob Harvey (don't use high-impedance input)
DONE 2/22
Table edge strips installed
Tightened FM trans antenna
Right side door exterior handle removed
Right side door interior handle fabricated
Door handle labels added
Short tongue jack to clear door - Charlie G
DONE 2/21
Table underside support sliders
DONE 2/20
Fixed power strips (were pulling out - mfg defect)
Center table redesign - Rodney W and MW
- Trimmed side tables round edge down 1/4"
- Cut 13" piece for left side "L"
- Mounted center left side "L"
- Cut 28" piece for right side swing-down
- Mounted center right side with bottom mount hinges
DONE 02/18
Bus paint polish & wax - Graham Jagger
I'll let him fill everyone in on the GORY details
DONE 2/16
Rubber floor edging installed - Thanks Steve R!
Temporary center table supports installed
- Changed plan for center fold-DOWN section :)
PA equipment shelf
- Mounted fixed shelf + brackets - Carl F, Ron, others
- Built pull-out equip tray w/ knobs - Dustin F, Kevin A
PA equipment install - Rob Harvey, all
- Amp install
- Wireless PA install
- FM transmitter install
- FM transmitter hood monopole antenna install
- FM transmitter improvements
PA Speakers - Ron S
- Used aluminum top plate for mount
- Mounted to roof hatch and wire up w/ banana plugs
Install cabinet drawer hold-down - MW
Caulk open holes in floor - Kevin A
Wire brush and 1st coat respray corroded hinges - Carl F
Improved spare tire mount - Joe Dobner
Add rubber to fire extinguisher tubes - Kevin A
2/15
Cut center fold-down tabletop (24x41)
Carpet found and installed in front cap
PA equipment shelf
- Cut, paint, test mount shelf
- Added trim to fascia edge
Paint exposed wood on table bottoms
2/13
Side fixed tables installed
PA install started
- Planned shelf for electronics
- Wired in switch
- Mounted power strip
- Ran wire for speakers through ceiling
Finished bus spare tire mount/winch - Joe Dobner
- Made a crank handle
- Some improvements planned
Side exit exhaust fabricated - Joe Dobner
- Removed old exhaust hangers
Remounted jump seat with reinforcement and good bolts
2/12
Began bus spare tire mount/winch install - Thanks Joe Dobner! (TO COMPLETE)
Installed new rubber floor where lift was - Thanks Steve Remchak! (TO COMPLETE)
Cut access panel in top front for PA install
Installed 2 hard mount invertors on wall - Thanks Carl F!
Installed 2 new "reinforced" 12v outlets on walls - Carl F
Installed single accessory battery - MW, Dustin and Malia
- Used existing 95 AH deep cycle batteries
- Used existing plastic batt box
- 80 AMP charging relay
- 80 AMP charging breaker
- 4 AWG charging cables
- 50 AMP discharge relay
- 8 AWG discharge wires
- Mounted on right wheel well with ratchet strap
Installed second helmet strip - Thanks Amy Mindick!
Began table installation
- Ripped down one table to 19" (and killed my circular saw!)
- Sourced table legs and mount hardware
2/7-2/11
Check all NC safety inspection items, get inspected - THANKS Rick B!
Got shop manual - Thanks Graham J!
Replace burned interior lamps - RB
Replaced 2 burned clearance lights - RB
Buy lug wrench - MW
Buy spare 2 5/16 ball for spare ballmount - MW
Finish batt isolator control box - THANKS Gordon T!
2/5
PA speaker plate test - successful as-configured
PA "big black amp" test - works great
Wireless PA tested - problems - hum + range
Steering box adjustment - added 1/4 turn - helped some
Finished sway control install
Set tire pressure (70/80 bus, 50 trailer)
Checked turn signals and brake lights
Re-adjusted front toe - added 1/4" in for 3/8" total
Tested trailer wiring - is OK
Organized keys and locks - MW
Test drive
2/3
Check tongue weight - appx 600 lb - OK
Estimate weight distribution - appx 59F/41R - OK
Hitch parts purchase - Ron S, Carl F, MW
Weight dist hitch install - MW, CF
Mount power strips on walls - MW
Mount 12v lighter outlets on walls (missing one) - MW
Run 8 gauge from R, L, and F to batteries - MW
Helmet strip install final bolts - Mike C, Amy M
Install custom extinguisher storage - Scott J
Mount PA speakers on plate for temporary / trial install - MC, Amy M
Reposition brake controller - SJ, Art M
Attach trailer to bus, install locks - MW
Re-attach loose bus interior panels - Art M
Red flag storage - Art M
Adjust trailer brake controller - MW
Test drive - MW, Art M
2/1
Sourced a spare tire mount - going to need some fab work to install
Spare tire and wheel picked up - Shawn W
Paint rusty swing door bottoms - MW
Repaired window latches (not permanent) - MW
New tires installed - Shawn W
Cleaned up bus windows, un-needed stickers, interior - Rick B
Found good 8 gauge wiring - Art M
1/31
Paint new front storage boxes - Thanks Rick!
Install final steering components - Thanks Dustin!
Adjusted steering box - DF
Mounted "jump seat" in rear - MW, DF
Caulked loose swing window panel - MW
Removed broken latches on window, made temporary sol'n - MW, DF
Replaced wiper blades - MW
Old Optima batteries tested - RB
Bus cabinet padding for timer boxes - MW
1/30
Trailer table storage unit - Thanks Dustin and Malia!
Trailer front storage boxes (one of 2 made) - DF
Install storage cabinet in bus - Thanks Rodney W and Matt T!
Complete display box padding - MW
Buy some 6" PVC tube to make extinguisher storage - DF
Started fire extinguisher storage rack (have a plan) - SJ and MT
1/29
Oil + filter changed - 10 quarts Rotella 15-40 - MW
Bilstein shocks installed - THANKS Dustin F!
Front brake fluid flushed - DF
Right + left inner, and right outer tie rods replaced, lubed - DF
Battery tray slider lube, battery install - THANKS Stephen W!
Trailer door threshold installed - THANKS Bowie!
1/26
Installed right shelves - THANKS Amy M, Mike C, and Art M!
Installed helmet strip - AM and MC - to be completed
Battery tray disassembled, cleaned, and painted - Stphen W
New glow plugs installed - THANKS Scott and Wes!
- TWO bad glow plugs found, explaining the hard starting
Bus fuel filter replaced - Scott and Wes
T^5 installed (Tarheel Temporary Template Timing Table) - THANKS Carl F, Rob, and Rodney!
- temporary tables so we can evaluate the size and configuration
Bought matching hitch pin and trailer lock combo - MW
Wire brushed and painted rusty floor (under lift) - Steven W
80% of the trailer contents transferred - all
1/25
Paint right shelves - THANKS Rick Butters!
Foam found (thanks Rob), delivered (thanks Scott) cut out, and partially installed
Pick up cabinet from Mark O - Thanks Mark V!
Trailer spare - Mark C is working on it
Spare wheel - Mark C is looking for one
1/23
Hitch and brake controller installed. THANKS Rodney W and others
Vinyl flooring installed in trailer. THANKS Ron S and Bowie G
Left main shelf and display shelf installed - RS and BG
Hinged lid + handle for display cabinet / work space made - RS and BG
Bus exhaust repaired, air cleaner replaced - RW, MW
Fabricated right shelf - THANKS Ron
Painted helmet, laser head strips - MW
Front storage planning and test fitting - MW
Remounted rear heater box - THANKS Adam L
Made trailer door hold-openers (one to do) - MW
1/15
Paint display storage and shelf - THANKS Rick B
Modify left shelving "foot" - RS
Modify (narrow) 2 existing right shelves - RS
Buy hardware for shelving install - RS, MW
Trailer hitch purchase - DONE (Uhaul $130 5000lb) - MW
Pre-cut remaining angle iron for right side shelves - MW
Test fit hitch to determine additional material needed - RS, MW
Removed bus seats - THANKS Frank C and Jason M
Removed wheelchair lift - RS, MW, FC, JM
Tentatively planned bus layout - All
Floors and walls painted - SJ, JM
Built and painted left main shelves - THANKS Chris S, Garry M, Mark S, and Ron S
Built display storage and shelf - CS, GM, MS, RS
Last edited by MikeWhitney on Tue Apr 19, 2005 11:32 pm, edited 19 times in total.
PostPosted: Wed Jan 26, 2005 9:44 am
Nice work Mike! Thank you very much!
PostPosted: Thu Jan 27, 2005 1:47 am
DIRECTIONS
I'm on the west side of Cary. Following are directions and contact info.
Go to 55 & High House/Green Level Road. Go west on Green Level. Turn right on Branton, follow to the end. Turn right on Picturesque Lane, go to the end of the cul-de-sac, we're the driveway on the right: 112 Picturesque Lane.
387-4949 home, 486-2979 work, 454-5445 mobile.
PostPosted: Thu Jan 27, 2005 10:59 am
Look! It's snowing!
I wanna help. :(
Diane (Hall) Bundas
PostPosted: Sun Feb 20, 2005 2:30 am
Some info about the FM transmitter:
The FM transmitter (currently set to 91.1) now has a range of at least 0.3 miles, maybe more under line-of-sight conditions. This is slight improvement over the 100' range we had before :) Also, the wireless PA now works up to 75' or so from the bus. Very nice - thank Rob H and Ron S next time you see them. The PA install is quite nice - we should also have reduced the feedback quite a bit by mounting the speakers "inboard".
 Post subject: Re: Bus update - wrapping up work, some help needed
PostPosted: Mon Apr 18, 2005 9:14 pm
Mr. Wizard
I broke my hand a couple of weekends ago and since I just had to have surgery on it, I don't know when I'll be able to use it again. I've got the steps and the bracket pretty much done, and I still need to fabricate the hinges. I figure there's about 4 hours of work left to do on them. If there's anybody else that knows how to tig weld aluminum (and has a tig rig), I'd love to have an extra pair of (functional) hands. Depending on how quick I get out of this splint I might be able to do it myself next week.
P.S. The Herrings are very nice people who drove me home from the hospital in their STi.
PostPosted: Tue Apr 19, 2005 12:36 am
[whine] I'm tired, I don't feel good, I'm too busy, I broke my hand [/whine] Blah blah blah, slacker.
;) ;) ;) Hope you heal fast! Sorry to hear about that! So are those grade 10.8 screws in your finger?
Bumping this thread for more updates in the top post. Thanks to Mitch I have a very high confidence that the AC will be up and running SOON!
PostPosted: Tue Apr 19, 2005 11:33 pm
Bump - see top post!
