ChrisSuich wrote:
I drove the bus for the first time today. It still rides like a bus, but it does have better power and the a/c is great. I think we need to have the alignment checked. If you let go of the wheel, it seems like it wants to drift left. I'll let Rodney give a long trip report after NCCAR.
More to-do's
Make power connection to trailer hot all the time so solar panel can back feed and charge the bus.
Chris, alignment was done at Cap. Ford - they even installed some sort of shims proactively. I think it has a LOT to do with the fundamental design of the steering - very very light, and WILL track with the road surface if you let go. As I've mentioned before, the bus will go where the steering wheel points - and if you let go and it tracks even the smallest amount, it will go there. I've tried to nail down a pull to one side or the other, but if you drive it long enough, I think you'll find it will go to either side depending on the surface.
All I know, the bus was fine when I turned it over to you
I used to drive E-350 Ambulances in a previous life, they did the same thing.
