Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: BIG Bus Days Saturday 5/7/2011 and 5/14/2011
PostPosted: Sun May 08, 2011 10:19 pm
KendtEklund wrote:
Donnie Barnes wrote:
No mention of the awning or generator. Might want to go back and update that part. I'm sure it was just an oversight.
I've got it covered - I'll be getting this
and this
for the next workday.
hmmn, do i smell ......... what is that smell?
PostPosted: Fri May 13, 2011 3:58 pm
ChrisSuich wrote:
Still left to do...
    Finish electronics wiring
    Fabricate platform for power inverter
    Secure counters tops; extend right side counter into "L" shape
    Secure file cabinet
    Secure jump seat
    Install new file cabinet for trophy supplies (Needs to be purchased)
    Quick brake bleed to check calipers for small air bubbles
    Debug dome light power problems
    THSCC logos
    Mount T&S Cooling fans
    Fix leak in roof ( midway on driver's side at seam over cable passage )
    Fix leak at top of rear door seal where door opener piston connect.
I'm still a go for this weekend. I would say we wait and see about the rain and work when there aren't downpours, but I hesitate to just declare that as new time given uncertainty of amount time needed to get tasks completed. Should the weather be bad, a half dozen or so folks should be able to work on these items inside the bus w/o too much interference.
If the weather is kind to us, a few more folks could be used to work outside the bus for transfer of trailer and other misc items. Sunday afternoon has a better forecast. If it is really bad tomorrow we can save the "outside the bus" work for then.
Given the forecast for this weekend and it's 7 days until the bus leaves for Roanoke Rapids,
I would say we need to focus on the following items.
    Get the PA system working
    Get the power strips energized.
    Secure the counter tops
    Secure the file cabinets
I will post back here Saturday with some status.
If I get industrious, I could setup a webcam on the bus. We'll see...
"Ruttin' is racing"
Chris Suich
Apex, NC
FunX 1970 Camaro LT1 ('95)
PostPosted: Fri May 13, 2011 4:27 pm
I'll be there a little after noon, still making up for mom's day for the wife.
If you electrical guru's could make it, we really need to get the hit list that Chris pointed out completed before the NCCAR weekend, especially the PA and wiring.
PostPosted: Fri May 13, 2011 5:32 pm
Matt didnt need speakers at the last event...
I will try and make this at about 10:30 or 11ish. I am far from a guru, but I can tie two wires together :mrgreen:
PostPosted: Sat May 14, 2011 6:53 am
Since it looks like storms might hold off until this afternoon, let's get started this morning.
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sat May 14, 2011 11:34 am
We are working...
:welcome:
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sat May 14, 2011 1:05 pm
This thread is worthless without a live webcam.
My Blog
PostPosted: Sat May 14, 2011 6:28 pm
ChrisSuich wrote:
ChrisSuich wrote:
Still left to do...
Morning was Don Ingerslew and myself
Late morning added Jason Watts
Afternoon added Rodney Wright, James Short, Keith Strassel
Today's accomplishments
    Transfered hitch
    Reworked desktop to extend for wider bus
    Secured desktop to floor
    Secured lateral file cabinet
    Secured new file cabinet
    Removed old sealant on roof
    More wiring complete
    Mounted mega power inverter
    Started roof leaf repair
    Added exhaust support midway (relieve header bolt stress?)
Still to do
    Swap rear wheels/tires between old bus and new
    Secure jump seat
    Fix leak in roof
    Low priority
    THSCC logos
Tomorrow we'll start at 12 rain or shine, earlier if you can if rain has stopped.
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sat May 14, 2011 7:01 pm
For the record... last week's participants
Chris Suich
Marcus McRae
Rodney Wright
Jason Watts
James Short
Keith Strassel
Ray Metts
Kourosh Neshat
Carl Fisher
Did I forget someone?
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sun May 15, 2011 11:04 am
The bus is open. :wink :wink:
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sun May 15, 2011 11:24 am
Free Japanese make seedlings. Bring your own pot.
"Ruttin' is racing"
Chris Suich
Apex, NC
PostPosted: Sun May 15, 2011 9:34 pm
Thanks to everyone who came out to help with bus setup.
Everyone who came out will get a year long plaque. Find me at NCCAR and I'll get it for you.
The new bus is VERY well setup. It is wider in there so T&S folks will find it much easier to maneuver around in there. We have external T&S plugs so the box just needs to be plugged into the pig tails and the timing heads plug into the junction box in the rear driver side of the bus including the wired display.
Trophies are in the new filing cabinet on the inside of the bus.
Please be away that the floor is higher, but the roof is comparable to the old bus. This means that the rear door is even SHORTER. So please watch your head (hint hint Rodney). We'd like to get a sliced 'pool noodle' to pad the top for this purpose.
The old filing cabinet is increasingly failing. Please be carefull pulling cabinets out as they *might* not stop. Also, use a bit of oomph pulling them out.
PostPosted: Sun May 15, 2011 9:42 pm
This was fixed. The doors now have stoppers on the tacks
PostPosted: Sun May 15, 2011 9:43 pm
Thank you sir.
PostPosted: Sun May 15, 2011 10:22 pm
JamesShort wrote:
Please be awarethat the floor is higher, but the roof is comparable to the old bus. This means that the rear door is even SHORTER. So please watch your head (hint hint Rodney).
If it's just for Rodney and I, the brain damage is already done. I wouldn't waste the $5 on a pool noodle. :P
