 Post subject: THSCC.com Unscheduled Downtime
PostPosted: Sun Dec 19, 2010 9:56 pm
Verve Hosting wrote:
There are drive errors on the server that hosts your website (erie server) and we need to run a manual disk check on the home partition on the primary disk drive. This needs to be done as soon as possible to properly diagnose and prevent further errors on the drive. The disk check has been scheduled for 9:00 p.m. EST on Sunday, December 18th (this evening). The server will be offline during the disk check. The downtime is expected to be about 1 hour. Please check the announcement at the client area for further updates:
https//cms.vervehosting.com/announcements.php?_m=news&_a=viewnews&newsid=321
We apologize for any inconvenience this may cause.
Verve Hosting
Carl Fisher
Be Cool to the Pizza Dude:
PostPosted: Mon Dec 20, 2010 12:05 am
The maintenance on the Erie server that was scheduled for 9:00 p.m. on Sunday, December 19th has been rescheduled for between 1:00 and 4:00 a.m. on Monday, December 20.
Carl Fisher
PostPosted: Mon Dec 20, 2010 8:41 am
The manual disk check that was run on the primary drive on the erie server did not fix the drive problems. Because of this, at times the /home partition becomes read-only, which requires the server to be rebooted. To avoid as much donwtime as possible, the sites currently hosted on the erie server will be movedto other servers. This migration will begin immediately.
Your IP address will change. If you use any nameservers other than Verve's nameservers you will need to manually update the IP address for your domain.
This should not affect the thscc.com website.
Carl Fisher
